Euro hinge question
Euro hinge question
Euro hinge question
Nat Robison
I'm planning on using European-style hinges on a frameless cabinet and I'm trying to figure out how to vary the overlay. I've looked at the instructions for Blum hinges on Rockler's site but can't find what I'm looking for. Do you vary the amount of overlay by adjusting the distance of the 35mm hole from the edge of the door?
Re: Euro hinge question
Hinge overlay
Short answer is no. The distance from the edge of the door to the middle of the hole is always 25mm+/-. The overlay is determined by three things: 1) the style of the hinge itself; 2) the baseplate; and 3) the fine adjustments within the hinge.
Euro hinges are available with different crank configurations depending on whether you want inset, half-overlay or full overlay, so you should decide that first. The baseplates come in a variety of heights to compensate for face-frame setbacks and other cabinet variations. Fine tuning within a narrow range of movement is accomplished with the three-axis adjustments of the hinge body itself.
Hope this helps. Your best bet is probably to get a catalog. I'm sure you can find one online for Blum or Grass or Salice or one of the other brands of hinges.
Ellis Walentine, Host
Moses Yoder
Re: Euro hinge question *LINK*
Moses Yoder
Do not vary the distance from the edge of the door, it may prevent the door from working. The overlay varys depending on the base plate you use. We use the 75T1580 hinge, which is a press in. You will probably want the 75T1550 screw in. Look at the page below and download the planning tool which should show you what hinge and plate to use. Download CLIP top BLUMOTION Planning Tool for Panel Construction.
blum planning tools
