ADVERTISE HERE - FREE TRIAL
Roundovers on inner side of trim?
I was thinking about putting some thin trim on some flat surfaces. I'd like to have a roundover on the inner side. The trim will be a bit thin. I'd also like to radius the inner corners.
Any thoughts?
Re: Roundovers on inner side of trim?
John McGaw
I have used a bit of applied trim that I made 3/4 X 1/4" which is fully radiused on the narrow edge. It is on my fireplace mantle and in at least one other location in the house. It looks pretty decent to me and makes a good shadow line but I've never tried it on furniture.
Ralph Lipeles
When I had to replace the screening on my screen room this summer I got to take a good look at the pine strips that were covering the edges of the screening. They were prety bad so I decided to make new pressure treated strips, 1/4" by 3/4". I cut the wood, planed to size and then used the router table to round off both edges. I used feather boards, top and side, and the strips came out great.
Ralph Lipeles
Couple things...
If you just run a roundover bit around the inside of the assembled trim, I suggest you miter the ends of the strips and let the corners be square on the inside instead of rounded. It may be my particular bias, but I don't care for the rounded inside corner look.
I'm With Ralph
George Colonel's Workshop-Havertown PA
Good Afternoon JL,
I make it a practise to ease edges with a 1/8th round over bit, especially important when splintery woods like oak will receive wear where two surfaces meet. Should joinery be already accomplished, I use my trim router to the extent possible, then sandpaper where the router won't reach.
George
You make it sound ease-y, Colonel
