Help, math beyond me. Dog house shed.
Gary Smyth
Engineers? I have built a winter dog house shed. The roof is essentially flat with only a 2” drop front to rear in 33”. The roof’s total size is 33” deep x 51” wide 2 ½” thick. I hit the big box store and found an opened bundle of shingles and fortunately or unfortunately they are the 40 year architectural kind. I used the bundle minus two full length shingles (20 strips out of 22) and excluding waste from trimming according to Owens Corning specs. The bundle weighed 80lbs, and the wood roof is ½”ply top and bottom with frame and battens with 1 ½” of foam insulation in between. If I removed the roof completely and weighed it I would be pretty close estimating it would come in near 120lbs. The shed roof is hinged at the rear so that the front can be muscled and propped up for cleaning. (Think of it like a car hood without springs.) I need to find out how much weight will need to be safely supported by two metal props to hold up the roof if the angle of the roof is raised to 60 degrees from basically horizontal. I don’t even know what math is involved. If it’s trig I haven’t got a chance. Can anyone help with a formula that I can understand? Also, the center of gravity will move with the lift. How is the point calculated where raising the roof on the shed could cause it to overturn by the CG moving rearward? Is anything under 90 degrees safe?
