toning a finish
toning a finish
toning a finish
Carol Reed
I have red oak edge grain butt joined to face grain, presenting a heck of a color contrast. Is there a way to 'tone' the contrast to make it look more uniform. Final finish will be sprayed NC Laquer. Not looking for a dark color. In fact, not much darker than clear lacquer with no color, but I am allowed to 'cheat' with a little color to achieve more uniformity.
On the last job I greatly liked spraying colored shellac to even things out, but I can't use as much color on this job. I used an Apollo HVLP rig, but I have, but not yet used, an HF HVLP rig. I am will to pick up one of those little sprayers with the jar on top, whatever they are called. :)
Thinking about Transtint dye....??
Your suggestions?
Re: toning a finish
Re: toning a finish
I have a CA Technologies TJR mini gun (HVLP - top cup) for toning that I do with shellac. I mix some transtint into 1 lb cut ultra pale dewaxed, then dial back on the material needle and adjust the fan to fit the area. They also can supply a special round pattern cap and nozzel set for toning. It's a great little gun with exceptional atomization that I also use to finish turnings. I'd give you a vendor, but the guys I bought from are gone.
Re: toning a finish
A little dab will do ya
Ray - Middletown, IN
Put a drop of transtint into the lacquer and spray light coats until you hit the shade needed. I have one of the little HF guns and it gets the job done. Not my first choice but it works.
Ray
Re: toning a finish
Re: A little dab will do ya
Carol Reed
The HF gun I have is the larger HVLP gun. I was thinking a mini gun. I'd like the one Mark suggested but 2+ bills. Nah! I'm trying to get out of the furniture building business.
So any suggestions for a mini gun or will the HF do?
Re: toning a finish
Jim DeLaney, Austintown, Ohio
Carol,
Harbor Freight has a gravity feed HVLP 'touch-up' gun for about fifty bucks - often on sale for less - that does a pretty good job with shellac, dyes, etc. It has a 1.0 mm tip, so any finishes used with it have to be thinned significantly, but 2# shellac, or water-based dyes go through it just fine.
Re: toning a finish
Think I paid $7.99
for the little gun, they keep raising the price and I think it is around $15 or so now. Maybe less on sale. I hardly ever get out my good gun unless I have a really large project.
Ray
Re: toning a finish
Re: HF gravity feeds
Carol Reed
There are two gravity feed guns available at HF. One is $15 (sale price). The other is an HVLP at $35 (sale price). I am headed into the big city tomorrow. Think I'll stop and look at them. I'd be inclined to the HVLP. What do you think?
If I were staying in the furniture business, I'd pop for the one Mark is advocating. Hopefully I have learned how to say no to more furniture projects, unless they are for my own home.
Re: toning a finish
I have both of them
however I have not used the larger one yet. They look almost identical so I expect them to work about the same, just different capacities. The little one doesn't hold very much at all so get the one for the size project you expect to concentrate on. I seem to get a lot of small projects, a foot here, leg there and the small one is the perfect size for those and any touch up work that comes in.
Ray
Re: toning a finish
I have both of the Gravity feed HVLP guns from HF. I wouldn't paint my car with them but they have done a pretty good job of spraying Lacquer when I used them. I usually use my Binks for larger jobs but when spraying inside shelves, boxes, chests, I have a lot less backwash from the HVLP - with the Binks the fog bouncing out envelopes you until you can't see what your doing. I also have a couple of the HF air brushes I purchased when they were on sale. They sure aren't a Paashe - but do a pretty good job for the real low price.
Re: toning a finish
Furniture Building
George Colonel's Workshop-Havertown PA
Good Afternoon Carol,
You expressed my sentiments exactly. I very rarely accept any outside work, and only if it comes from an old customer, or one which sparks my interest. It doesn't hurt to say "no" before "Thank you.
George
