We value your privacy.
Yes, I have cleaned a cabinet saw without removing the top. It is a PITA, but it can be done. Wear old clothes and be prepared to take a shower afterwards.
I used kerosene - it is less expensive than mineral spirits. I put a layer of rags in the bottom "chamber" of the saw. I got out a brass bristled brush and dipped it in my little peanut butter jar and scrubbed away. I also had a spray bottle with kerosene. I would recommend removing the belts or shielding them from the kerosene (plastic wrap, rags and tape). Obviously you need a LOT of ventilation.
My Uni did the same thing. I have a left tilt so not sure you can reach the same parts I can. All I did was remove the insert and blade, I used a full pressure air gun (removed the regulator/limiter from the gun) and blew out the gear mechanisms while rotating them. I left my dust collector on to catch the debris. Then I sprayed the heck out of them - again while rotating them - with a dry spray lubricant. That was about a year ago and still no squeaks.
