lacquer finish over
lacquer finish over
lacquer finish over
smoo
hi. i was wondering if you can spray (with success) a lacquer high gloss over acrylic spray paint on bamboo. i have been googling but with mixed opinions.
Re: lacquer finish over
Maybe
...but I doubt it. Lacquer thinner cuts through a lot of other finishes. Only a test with your particular finishes will tell. You may be able to do it if you spray on a barrier coat such as shellac first.
Make some samples and try it out.
Ellis Walentine, Host
Re: Maybe
smoo
ellis- thank you very much for your quick response. i will test a few spots tonight. no doubt i will get back to with the results. thanks again.
-smoo from jersey
I doubt it....
Dick Coers
Lacquer solvent is what is called a "hot" solvent. That stuff melts about anything (well except poly and catalyzed finishes). You can put many finishes on top of lacquer, but I've not found any that I can put lacquer on. If you try a little sample, keep the first coats really dry. Just misting the first coats can sometimes lay down a barrier, but with lacquer, the latter wet coats melt right in. Good luck!
Re: I doubt it....
Ken Oakley- Sunny St. Cloud, Fla.
I have had luck spraying lacquer over other finishes by first applying a few coats of Krylons clear matte spray, spraying light coats of lacquer over the Kylon. Again, test before spraying the whole thing.
Howard Acheson
Not a good choice. In fact, applying a dab of lacquer thinner the determine the finish on a item is one test to determine that it is waterborne finish. Lacquer thinner will soften a lacquer and a waterborne finish.
What is the item and what are you trying to accomplish? Why do you want to overcoat with lacquer?
smoo
hi guys and thank you so much for the advise.
i am working on a small project, which is making a 'longboard' skateboard (40" / 10") out of pressed bamboo.
as suggested, i tested the lacquer spray over a small section of the board last night.
this morning there was no negative effect whatsoever to the bamboo or the acrylic spray paint (5 coats).
i am on my 5th complete spraying of lacquer now and the board has a wonderful glossy coat that appears to be very, very strong.
