OT Copper weekend discovery
Gary Smyth
Have you ever seen this? Yesterday at an estate sale I found this copper bucket as a planter caked with mud, old leaves, and a dead geranium. I have no idea of the age or the origin but the bottom drew my attention. Have you ever seen a stitched (tabbed) bucket? This is new to me.
I bought it for 50 cents and in a old tinsmithing book, an illustration shows a crimped bottom item with what looks as if it might have similar stitching. I’ve not seen this before.
On to the my questions. I cleaned the inside of the plant debris and filled the bucket with water. There are three small leaks. Which is probably why it became a planter. They each bleed out a drop at a time. How would you stop the leaks? Have someone (who would be able to do such work?) resolder at the leak area? Place epoxy on the inside of the bucket? Other suggestions?
Re: OT Copper weekend discovery
It's similar to a technique we used in attaching ducts to other ducts when I briefly did tin work. An interesting detail.
The correct repair would be resoldering, and any competent sheet metal shop should be able to do it (it's been more than 35 years since I worked in the trade, so I don't know how many modern tinbenders can still solder; it's not a difficult skill, but I don't know if the modern shop still supports it). Phone around to the listings under "sheet metal" in your Yellow Pages.
You could do it yourself with a soldering copper, a way to heat it, some solder (different from electrical solder), and the right flux; but gathering all that and spending the hour or so practicing might all add up to more hassle than finding someone to do it.
I suppose it was a repair, done after the bottom was damaged, or a way to extend the height of the pot from the materials at hand, with the top piece being not quite wide enough; I can't, offhand, see another reason for the maker to have done that.
It may have been silver soldered but since you don't now which solder they used you may create more leaks when you heat it. A good copper smith or jeweler should be able to fix it. However unless your trying to restore it to keep it's value I would simply use clear epoxy.
Moses Yoder
Moses Yoder
I repaired an aluminum boat with J.B. Weld and it worked fine, even for some 1/4" holes from prior fittings. If it comes out a drop at a time I would probably just work in some J.B. and call it good.
Alan in Little Washington (NC)
I wouldn't touch it until you get a better idea what it is and whether its provenance gives it value. In any case, in the mean time, it would be easy enough to just put a removable plastic or vinyl liner in it if you want to use it as a planter.
Ken Oakley-Sunny St. Cloud, Fla
I agree with Alan. It might be worth big bucks on Antique Roadshow and even cleaning it could decrease it's value
john Veerkamp
We have some copper pots made in Turkey about 20 years ago, they were constructed in a similar fashion. The side is one piece worked into a "cylinder" , stitched together and braised. The bottom is a single piece, folded up about 2", stitched and braised. The wrought handles are also similar. Braising is well within the ability of most handy folks. Good advice on verifying it's antiquity before doing any repairs. A cheap , easy reversible fix is silicon caulk.
The Turkey connection might work
Gary Smyth
as the man of the house had been with the state department and had plenty of overseas work. Many of the books available at the sale had to do with that area as well as the rugs. This bucket was outside of a gardening shed/cold frame half buried thus the almost nothing price. Had it been inside and clean the price would have been additional. The handle is held by a ring of copper and is well worn at the top where the handle and ring rub. It might be old or not. I'll take the earlier suggestions and see if outside repair is worth the price. If not, I'll use something reversible and keep it as a (yet another) conversation item.
Red Green would...
Joe Pack
Ol' Red would wrap it in duct tape and hoped it would hold water. If not, he would call it a drip irrigation device and sell it to one of his lodge buddies.
