octagonal bench problems
HapaJeff
This problem is sort of difficult to put into words, but I'll give it a try:
I am building a series of octagonal benches to go around trees. The seats are comprised of six 2” wide slats that will be spaced 1/4” apart, forming six concentric octagons with an outside “diameter” of 66”.
I spent some time making a cross cut sled to cut the 22.5 degree angles, and it is extremely accurate.
The problem I’m having is cutting the slats so that the resulting rings are spaced no more or no less than 1/4” from the adjoining slats. If my cut is off by 1/64” of an inch, by the time the pieces of a particular ring are assembled, the ring is spaced noticeably further away from the previous set of slats.
I’m looking for a way to easily cut the slats so that the resulting rings are 1/4” apart from one another.
