Shop update and Electrical Question
Allen Bryant - Bumpass, VA
Well the draftsman and I have still been hashing out a plan, but we are getting closer to having the final plans ready right after the first of the year. Considering he is doing this as a favor and promise of trade labor I'm not going to push him to hard to get done.
The contractor was having a slow week so since we have a rough foot print and size of the building he went ahead and came out this past week and cleared the trees and stumps out of the way. That's about as much as they can do till we get the permits.
Now for the electrical questions
The specs for my table saw states that it requires a 220v, 15 Amp circuit, but the max draw from the motor is 14 amps, isn't this cutting it a little close. By the specs I can install a 14-3WG wire on a 15 AMP Double Pole breaker. If I go to a bigger circuit do I run the risk of burning the motor out because it could overload well beyond 14 amps prior to tripping the breaker. I was wondering about running 12-3WG but with the same 15amp breaker. Around here I can put a higher class wire on a lower class breaker just not the other way around. This would mean that if I upgrade to something higher later that I would only have to swap out the breaker and would still trip at 15 amps without having to worry about overheating the wire or the motor.
Second question, for people who have dedicated buildings for their shops does anybody have a second power source run to it and not a feed from the main house breaker? If so was there any problems on getting the electrical source run by your provider? Even though I have can run up to 150 amp sub panel off the house it would be easier to get power to the building by coming off of the main transformer ( if it can handle it) than to come off the house feed.
