Spiral Router bit Question
I have a spiral 1/2" solid carbide upcut (I think) router bit with a 1/2" shank.
I bought it to be a go too bit for hogging material and pattern routing using a guide bushing. It does not cut as easily or aggressively as I expected. It "feels" like it is dull both when you touch the edge and use it in the router. I have had it for years and don't remember it ever being better. So, do you have one of these and does it have sharp cutting edges? Does it cut well? Should I send mine out for sharpening? Or should I just go back to straight fluted bits?
Re: Spiral Router bit Question
Dave Paine
Barry, I have several spiral bits, including 1/2in. Some recently purchased and hardly used.
The splines do not feel sharp. However, the tip is VERY sharp. I did not lower the bit as much as I thought in my router table and managed to get a cut just be passing my finger across the top when moving a piece of wood. Slight cut, but it showed how sharp this was.
I prefer the cut of the spiral bits, smoother than straight. Also less vibration.
It seems many people with box joint jigs prefer the spirals for this use.
If you are not sure whether yours in sharp, I would send it to be sharpened.
Dick Coers
Spiral bits are made for plunge cutting, by cutting all the way to the center of the bit. Most two flutes will not cut to the center unless they have additional carbide on the tip and are sharpened to the center. Are you sure it's not a spiral end mill? Those are made for cutting metal, and do not have as sharp of an edge as router bits. By coincidence, I too am missing skin from a spiral bit. I checked the engagement of a huge bit (1" dia., 6.5" cutting length, 8" overall length) in the spindle of the CNC at work. I give it a spin as a final check before hitting the green button. I've done that for 9 years, but this time my hand slipped on the collet nut, and it took off divots of skin on three fingers. Yup, they are very sharp. Remember, if you get it sharpened, it won't be 1/2" diameter any more.
Bruce, a MN Galoot
Yup, I have one of these. It's expensive as the dickens ($55), solid carbide, sharp as it can get and absolutely excels at plunge cutting. It's the primary reason the vast majority of my mortises are 1/2". It clears chips very fast, too.
I'd recommend you find a premier sharpening service and have it sharpened.
Jesper, Denmark
Jesper, Denmark
IMHO. the endmill style carbide router bit does not cut as well as a straight bit, or what Festool call a spiral fluted bit. The Festool style is more like a straight bit, but with skewed side cutters. Does not look like a twist drill with pointed edges.
del schisler
i use the up cut bit mine is amana brand and it cut's very well. and is sharp. I would get it sharpen or get a new bit. It will out cut a streight bit for sure. I use router's all the time. A good web site for router stuff is the router work shop which used to be on pbs but not any more here is the site. Their are lot's of fellow's that know their stuff . http://www.routerforums.com/
pecker
I bought an MLCS spiral cutter that perfromed just like yours..it felt dull and cut poorly right out of the packege.
I tried an Amana version, which cost a little more, but the difference was night and day. Still works well after many usages.
