Grainy Filling Walnut plywoord
Mark
Built some floating shelves using some scrap walnut ply..last time I used some walnut ply, after oiling and a few coats of poly urethane I wasn't too happy with the finish...
This time i was thinking of filling the grain first with a pumice and oil slurry...thoughts?
Re: Grainy Filling Walnut plywoord
Bart Goldberg
Re: Grainy Filling Walnut plywoord *LINK*
Bart Goldberg
What was it about the finish you did last time that you did not like?
If I was going to fill the grain before finishing - i'd use the following:
Homestead Finishing Grain Filler
paul in AZ
For a water based filler try Timbermate. It takes dyes if you want to add color and never goes bad. Just add a tad of water to thin it out to whatever consistency you want.
Bart Goldberg
Bart Goldberg
Your Idea will work - its outlined in an Article by Jeff Jewitt on the Fine Woodworking site. Note that he does specify using Linseed oil.
Here are the instructions from his article:
To begin, pour boiled linseed oil onto the wood and rub it in with a cloth. Sprinkle pumice (use the finest grade, 4F) over the surface and work it into the grain with a cotton cloth, using a circular motion. Use roughly a teaspoon of pumice for every square foot of surface. Add more oil if the mixture appears chalky. The oil filler has a generous open time, so you really can pack it into the grain. Examine the surface against a low-angle light, a technique known as backlighting, to make sure all of the grain is filled.
Last, with a clean, dry cloth, lightly wipe across the grain to remove the excess filler. This step is complete when the surface feels smooth. Let the filler dry overnight, and then examine the surface against backlighting a second time. Some open-grained woods, such as oak, may need a second application.
The filler should dry for at least 72 hours before applying a clear coat. Most finishes are compatible with this type of filler, including water-based finishes. But to be on the safe side, a 2-lb. cut of dewaxed shellac will seal the filler and allow the application of any finish.
