Wooden Hinge questions
Several years ago I made a batch of wooden hinges. They are essentially a pair of matched finger joints with the ends rounded and a hole drill through them for a pin. I made mine out of half inch stock with quarter inch fingers. They look a little clunky and massive on a jewelry box.
So, do you think making them 3/8" thick would significantly weaking them? The pins are 1/8" brass rod. I am trying to figure out if the thickness of the leaf makes much difference in their resistance to splitting? How about using 3/16 or 1/8" fingers?
Re: Wooden Hinge questions
You could go with smaller pins. The steel or brass will be the strongest part of the joint so you could get away with much smaller although drilling straight holes any distance with smaller bits would be a challenge.
It sounds like the ones you made were about the same size as the ones I did and I agree, they are a bit clunky for smaller projects. Can't help you on the strength issue for smaller sizes. I do think that splitting would not be much of an issue if the hole is drilled very slightly oversize. You would need to figure out a way to capture the pin then.
Jon Weisenbach
I see no problem with going thinner as you state. These are 1/4" fingerjoints w/ 1/8" brass rods for pins and they have held up just fine! They are on 1/4" maple material!
