Syringes and check valves
TomD
I need to accurately pump glue components, and I know one way to do it is to use PD dose/O-ring syringes. I use these already to measure one shot at a time, but I want to pump two component epoxies a little faster. To convert the syringe into a somewhat more self-tending pump, I would like to get a Y fitting for it, either fitting directly to the syringe, or to a tube, and I would like to have a check valve on each side of that. Voilal, a pump.
Do any of the medical folks here know these products, and can you suggest what I am looking for and where it can be cheaply bought?
These are the syringes:
http://www.squirrelstore.com/site/744999/page/517489
Valve wise maybe something like this:
http://www.smartproducts.com/check_valves_series_500_miniature.php
Re: Syringes and check valves
Bill Tindall
What you describe is called a "syringe pump". They are common laboratory items which could be bad news as lab stuff is expensive. However, there is a robust market for used lab stuff. I have a daughter that works in a frugally funded lab and she buys most of what she needs used from these sources.
Rick L
Re:More info needed
Rick L
As usual, I think more info on what you are doing and what you are using for glue would allow for a better answer. Often what you want is different what you need...
http://www.albioneng.com/
http://www.albioneng.com/home/products/accessories/cartridge-accessories.aspx/rptProducts=2
Albion is one of the top sources for epoxy applications.
They have split cartridges with different ratios and static mixing tips. Sounds like you are keeping it low budget. Lab grade metering/mixing equipment is very expensive.
http://www.michaelengineering.com/crank_pumps.shtml
http://www.syringepump.com/index.php
Re:More info needed
TomD
Thank you both. Some great stuff to follow up on there.
I did remember a potential problem with my arrangement. I think it is by-passable with machine work, but that would take it back away from something that more people could use. The problem is viscosity. I use these syringes a lot, but they are slow to fill with epoxy, and while larger holes could be drilled that would probably preclude using the stock valves. Still worth a try, but I am less excited.
I am pretty familiar with the epoxy metering options, but it is amazing how few people in the boat building community actually use them for personal projects. I see them in yards. I have a good version that a home machinist can make, but: 1) non-machinists aren't going to get one 2) the syringes are pretty much 50 percent of the build so why not use them 3) the syringes are more versatile for switching in and out for different mixes 4) they are disposable, as far as cleaning and replacement kits are concerned 5) They are easy to calibrate if the scales are reliable for the degree of required accuracy. One could calibrate against the scale and arm throw, rather than having to do a bunch of test runs.
http://www.syringepump.com/continuous.php
Seems like the part/s I am asking for would be the bits dangling off the syringe in this picture.
An option I am not going to try, would be some kind of CNC or linear actuator. Sounds crazy, but for a person happy with the electronics, and able to use the motors elsewhere, it would be very programmable.
Jesper, Denmark
Re: Alternative......
Jesper, Denmark
I have goten tired of dosing pumps on West system epoxy, messy, difficult to clean and leak air into the containers, causing degradation - particularly of the "hardener" component, which is hydrophilic.
Instead, I have a cheap electronic kitchen scale and weigh out the two components instead. Turn on the scale, put the mixng container on it and tare it. Pour in one component, and then the other component in the correct ratio. The specific mass of both components are close enough that the mixture is in the right ratio both by weight and by volume.
Agree
Bill Tindall
I cook by weight rather than volume so I have coarse and fine scales at hand. I always weigh epoxy components. Once you own a a scale, which have become cheap, all sorts of uses reveal themselves.
Re: Alternative...... not really
TomD
That's a method people should know, but it is nowhere near as fast as a pump (or at least not for typical small and medium batches. I Started weighing, maybe 20 years ago, when the first electronic scales hit about 20 bucks locally. I think at that point it was marginal for weighing west where the 5-1 ratios in small amounts push the plus of minus .2 gram accuracy of the scales of the day. Currently cheap scales are much more accurate.
Another scale that is really cool was this one I saw on a website, but it went off line with the site, and I have never seen it since. The guy made a fairly conventional beam scale with a long sawzall blade as the weight scale beam. He then made up weights that were in the proportion of the components of whatever mixes were being used. That is very fast, no further calculations, and very accurate. You would then position the first weight out on the beam, and with the container zeroed balance the resin. Then hang the second weight form the first and add the hardener. Same weights worked anywhere on the beam. The design was compact as somehow the beam and ledge were on the same side as the pivot. Really clever.
But all that said, large projects can have a thousand pounds of epoxy measured out at one ounce or two at a time. There is no substitute for a pump, and really, at that level, there is no substitute for a gear pump system. I would spring for one of the many commercial version, it's just that while at the Wooden Boat School the one I liked best was home made, so I have always looked in that direction.
There isn't one method that works best, even if If had a gear pump, I would still measure the small batches with o-ring syringes mounted in bottles, and do the large batches in pails from measuring cups, or sticks.
I still need to track down that valve part in the pictures.
check valves?
Bill Tindall
Is it check valves you are looking for? Try the fluid handling companies- Parker Hannifin, Swagelock and the like.
Rick L
Re: Still no USEFUL info?
Rick L
You haven't given any real information on what you are doing! What are you making? What kind of epoxy? Ratio? Based on what little you said your ways of dealing with epoxy seems wasteful and inefficient. Running small amounts of epoxy in tubes would seem to freeze up and waste a syringe worth of adhesive. No mention of mixing tips.
Re: check valves?
TomD
Thanks Bill, your technical knowledge is appreciated!
TomD
The epoxy is not mixed in this system, it is dispensed. The pump I am working on is similar to the 306-25 Metering Pump, here:
http://www.westsystem.com/ss/pumps-and-metering-equipment
The pump I have plans for is a better version of that pump, and I am contemplating modifications that would make it easier to build etc... Possibly with a loss of some efficiency.
