Splines on the corners of boxes????
I am making another batch of boxes for Christmas presents. Mitered the corners and am installing splines through the corners by cutting slots through the corner and installing splines and then sanding them flush on the exterior. I have done this many times before and as I recall I ripped the splines with my WWII blade and installed them. Took a couple of tried to get the thickness just right but after that it was easy. I mangled my WWII blade on a staple (See post below) and I can't seem to get it to cooperate at this level. It "appears" to have very minor chipping on the a few of the teeth but apparently that is enough to mess up the cut.
So, how do I do this? I have ripped some strips and they are not smooth enough and not accurate over their length. I ran them through the Performax on a sled. If I send one through and get it just right, then send its brothers through, they come out different. Four come out thicker than one. If I send one through and it is VERY slightly too thick and I send it again without changing anything, its too thin.
So I take the one that is just barely too tight to press in by hand and tap it into place with a mallet? (don't want to split the box) Or do i glue in the ones that are Slightly loose with Epoxy? (gap filler).
And, what do you think of CA for this application, is it permanent?
