Best thing I've done to my Pipe Clamps
I have maybe fifteen pipe clamps that I have collected for the forty some years I have been doing wood working. There are a couple of different brands and styles. The manufacturer changed them over the years and some have a foot on them and many don't. Recently I had some scraps of Baltic Birch Plywood left over so I made wooden jaw liners for them. Cut them to about 5" by 2", drilled about an 1 1/4" hole for the pipe, rounded all the edges (even the holes) with a round over bit, and screwed them to the jaws. Had to drill holes in the jaws for the screws, but it was easy, the metal was fairly soft. If the screws poked through, I filed them flush.
This turns out to be a significant improvement in handling the clamps. Now the all will sit up, at the same height, the handles clear the table, you don't have to use cauls, and when you install them from the top they will sit up in that direction too and the handles clear the table. Wax or otherwise "glue proof" the jaws. Make a few spares. Make the hole loose so as not to bind. A little wider would be OK or better. Solid wood may work as well, but the BB was too pretty to throw away. These are holding up well.
