finish padauk table
finish padauk table
finish padauk table
Gordon Creswell
I would appreciate any help/advice for finishing a kitchen butcher block Padauk table. I know it will darken with age but my main criteria is for a durable, non-glossy finish. Is there a commercial product or wipe-on mixture of tung oil, varnish and turpentine that you could reccomend.
Gordon
Re: finish padauk table
need more information
Bill Tindall
What are you going to do on this table- butcher sheep, eat breakfast (that ought to cover the range of possibilities)? How it will be used will determine the finish.
For an eating table nothing beats urethane varnish or conversion varnish if you can spray. Varnish can be applied thin to build a coating of what ever thickness you desire and delustered or rubbed to what ever sheen is desired. The commercial "Danish Oil" finishes of the 70's were in fact delustered, thinned lacquer or varnish.
Re: need more information
Gordon Creswell
Bill:
Many thanks for your reply to my post. The Padauk table is for breakfast eating. do I control the gloss/sheen by fine sandpaper or steel wool to the final coat of varnish. What formula do I use for the tung oil, urethane, turpentine misture for wipe on application. As you can see I am a relative novice who appreciates fine wood working.
Gordon from Santa Rosa, CA
Bill Tindall
No wipe on finish will have the durability of straight urethane varnish. Varnish of all sorts are formulated way to thick, in order to meet EPA emission requirements, like varnish has any measurable contribution to air pollution. The solution to this problem is to thin it to where it will flow better. If you thin a urethane about 4 parts varnish to 1 part mineral spirits or naptha it will flow out nicely using a high quality brush or one of those sponge rubber disposable paint "brush" affairs. After the first coat dries, sand with 320 grit stearated paper and recoat. Rub out if you wish after the varnish has thoroughly hardened.
I agree with Bill. You don't want a shop-made wipe on finish for an eating table. Go with varnish, or at least something without the non-polymerizing ingredients. A few coats of Seal Coat shellac actually has held up well on our kitchen island table.
If you lay on a coat of varnish to a dust free surface and let it dry in a relatively clean atmosphere, you should have no trouble building a nice finish with two or three coats. Various rubbing strategies are available to create a surface quality that suits you.
