Framing a basement remodel - base plate ??
Tim Greif - West of Chicago
Oldest son is getting ready to finish his basement. Code says you need a pressure treated sole plate or anything else that touches concrete. No problem there but he has to use hot dip galvanized to toenail the studs into the plate at bottom. Normal nails at the top plate and everywhere else. He doesn't want to keep changing nails in his borrowed Pasload from sole to top plate. Are the hot dip really needed for the ACQ stuff in a basement? He's thinking of using a double bottom plate with the bottom member being treated and the second plate normal lumber so he can just use galvanized to sandwitch the two. He's shooting the bottom plate into the concrete with a gun using galvanized nails. That way, all stud fasteners are normal nails.
Any thoughts?
Re: Framing a basement remodel - base plate ??
Jason Roehl in Lafayette, IN
Yes.
Today's treated will eat regular steel nails in short order. Galvanized or stainless fasteners anywhere there is treated lumber.
I don't see why he couldn't do a double sole plate. Might make it possible to build the wall flat on the floor and then stand it up on top of the treated sole plate.
Jason
David Yoho
Code is code, I suppose, but I've seen DIY TV shows where they use this new blue colored framing lumber along with a strip of some kind of plastic vapor barrier between the concrete floor and the wood. Perhaps this combo changes the need for PT lumber in this situation but don't know how it plays throughout the US for code.
John McGaw
If code permits it, and I'd be certain to ask specifically, I'd use stainless nails rated for the type of lumber being used. Actually, if it were me and the situation was such that I could build the wall flat on the floor first, I'd use stainless screws up through the sole plate and down through the top plate into the studs but so many basements have ragged ceiling heights and lumpy floors that this isn't always doable. I'd prefer stainless nails since, even though they probably cost more than galvanized there seems a better chance of using up the extras on some other project.
The "blue Wood" is treated with a Borate or boric acid and is much gentler on fasteners than the ACQ Stuff. Until recently the pirate stuff was not suitable for out doors because it was water soluble and the ran washed it away. Some body found and answer to that, but even with out that it would be suitable for the bottom plate.
Check with who ever you bought the lube from and be sure you know what the chemical is and then use suitable nails.
Justin Szeliga
I've used the PT plate & build the wall on top of it method on a few basements. Helps keep the wall out of the occasional flood too. Using a traditional framing technique like building & raising the wall will require an extraordinarily level ceiling or building the wall a bit low & shimming to meet the top plate. With a badly out of level ceiling I've found setting top & bottom plates first then filling in with studs easiest.
There are other solutions
I kind of like galvanized anyway, and use them a lot even when they're not required. But if he wants to use bright nails where he can, but stick with the proper galvanized nails into the bottom plate, there IS another solution:
Bruce, a MN Galoot
I wouldn't use bright nails on that. The green-treated lumber we get is really wet and would rust out regular nails in no time.
Two tidbits picked up from Mike Holmes
Rod Peterson—Ormond Beach, FL
Canadian DIY TV star:
He never builds basement walls on the floor—too much variation in the ceiling height, as others have mentioned.
He mostly uses screws in framing applications.
Of course that takes the fun out of using the big dog, but changing nails isn't that big of a deal. Frankly, you're going to be shooting most of the bottom at one time and then attacking the top (or vice versa), so it's basically only one change, anyway. It's the same process when you need to reload, which you're bound to have to do at least once, I'd bet.
Rod
nickb
I'd recommend stainless nails if he's going to use a PT bottom plate - the current generation of PT lumber is really, really hard on steel (I've heard, at least anecdotally, of even HDG fasteners rusting out in a short time).
Has he considered framing with light gauge steel? I'm going to be finishing out the part of our basement that isn't the shop, and I'll be using steel. Some different techniques, but so easy to carry and they all come straight (try to find a straight 2x4 lately?).
