Re: Can you post the process? *LINK*
Craig Daymon
I think most people would consider that a "scoop" rather than a "spoon". If large, like the size of the salad tongs shown, a "ladle".
If the idea is to make a more traditional wooden spoon, it is easy to turn the basic shape (aside from dealing with some vibration in the relatively long and narrow handle), given that turning the bowl end will involve turning air part of the time as it will only make up at most half of the bowl. I would use a forstner bit to drill a shallow recess where I want the bowl to be (before beginning turning). Once turning is complete, you will have to carve the bowl of the spoon.
You could turn the bowl, if rather than the traditional egg shaped bowl, you wanted a round bowl. Though, this would require a lathe with a good swing to turn a spoon of a traditional length.
Most wooden spoons have shallow bowls.
I posted a picture of a spoon I made for my sister recently (before completely finishing the bowl). Mine was turned from 3/4" thick stock, which I mounted slightly off center to give me more wood to carve out the bowl. It was far more than enough. I used rotary carvers. You could also carve the bowl by first turning a spindle, possibly with a morse taper on one end to push in the head stock, with an egg shape on one end. Cover that egg with adhesive backed abrasive (relatively coarse, maybe 80 grit) and spin that in the lathe, pressing the bowl region against the egg shape to carve out the bowl. I would still recommend starting with a forstner bit recess, which will make it easier to center and control the egg shaped sander and help lessen what needs to be carved.
Finish shaping the outside using a disk sander, which can easily be made out of a disk of plywood for the lathe. (One of our local turners turns/drills a recess in the back which he expands his chuck jaws into to hold it. Makes for a very compact design. He has 4 with different grits on each.)
Below is a link to a site dedicated to woodturning that has lots of articles on turning projects. The link is to their page for Spoons and Spatulas.
Woodturning Online Spoons and Spatulas
