We value your privacy.
my shop is finished, but since now i have a large lathe, a 16 inch jet planer, a table saw, and a 21 inch drumsander taking up floor space, i was wondering about building a base for the sander, saw and planer and putting wheels/castors on them...
anyone got input? the planer weights around 600 lbs and the sander probably around 200... was just thinking of cutting some rabbits on a 2x4 or 4x4 and bolting them into a square, but hey... what do i know..
if you have a wheel that is rated at 200 lbs, can 4 of them carry 800lbs or max of 200 for all four?
remember, im a liberal arts major.. we dont do math or designs, we make things pretty...
I don't know about using 2 x 4s. I have one mobile base on one of my band saws that uses oak 2 x 2 that is ~2' long. Got the hardware from Rockler.
I have a General mobile base on my cabinet saw - works well.
Anyway - yes - if a caster is rated at 200 lbs, 4 of them would hold 800 lbs. I wouldn't go to the full maximum - I'd probably go for a maximum of 600 lbs.
If you wanted to make your own bases, I'd use hardwood, not softwood. I'd use hard casters that lock.
Having a small shop, I've put all my machines on mobile bases. I have a few commercial ones, but I prefer wood/home made. I've had good luck with 2 x construction, held square with 3/4" mdf or plywood. Go with big wheels. I'm using the 4" from LV. They roll much easier. I've used two non-swivel and two locking swivel for each platform.
In a vertical load, with the load resting on end grain, wood will support about a 1000 lbs per square inch. (Actually the number varied widely with species and grade, but construction lumber like common 2x4's can be counted on to support 1000 lbs/sq in. as long as they are not too tall and skinny in which case they buckle, but you are well below the danger of buckling.) Cutting half lap joints cuts away half the strength, but it still leaves you with enough wood to support about 2600 lbs per leg.
Be sure to use sturdy bottom to evenly transmit the load to the casters. Either put blocking in the corners glued to the verticals or you could just double the posts and eliminate the half laps on the really heavy stuff. And/or use 5/8" or 3/4" plywood or OSB for the bottom.
Bigger wheels roll easier than smaller ones. They roll easier on a clean floor and are better about bumping over chips and debris. Trust me, you will appreciate bigger wheels. And I agree about two locking and two fixed.Actually what might be best is two that are fixed direction that lock and two that swivel and don't lock. Some of mine have locking swivel casters and the locking mechanism tends to get "lost" under the machine sometimes.
Also, Heavier duty ones roll better and hold up better than lighter duty ones. So if the $$$$ are not significant, I would double the rating or more. Instead of 4 200 lb casters to support 800 pounds, I would prefer four 400 lb ones. Probably not necessary, just better, especially if you are using cheap Harbor Freight casters.
You have and opportunity here to make these bases useful cabinets. "Skinning" the outside of these frames stiffens them and makes them much stronger. You could add doors or drawers and use the space for storage. Or use it for some sort of dust collection application.
The general rule for castor load selection is to divide the total load to be supported by three on a four castor support. If you know you will be moving over a rough or cracked floor or threashold then you may select an even high rated castor. For heavy load, larger diameter ball bearing castors are best. The castor tire material should not be soft if a rough floor surface.
Most of my tools are mobile. My table saw uses the base supplied by Jet and it works well. Planer, drill press, mortiser and chop saw are on stands with the 3" swivel casters from Woodcraft which I find work very well. I made a cart for my lathe and went with 2" casters from the Borg and I'm regretting it.
Always go bigger than you need. If you go smaller, your almost guaranteed to regret it. Bigger wheels do roll better on dirty and uneven shop floors, plus they don't get hung up on things.
I like the idea of making rolling cabinets under the tools where possible. More rigidity and none of us ever seem to have enough storage.
I have all my machines on mobile bases I welded up out of angle iron scraps and 3" wide flat strap. Most of the casters are those red 3" ones that Woodcraft sells. I forget the rating, but they are fine for my heaviest machines, an old PM 100 planer and a General 591 bandsaw. Years ago I tried some robust looking casters from Harbor Fill, and that's about what they were good for. The weight rating was higher than the Woodcraft ones IIRC, but they didn't work as well. I prefer to have all four casters swivel, makes maneuvering much easier.
A friend of mine has a PM 16" planer (3000# or so) on a mobile base he made. It's all in finding good casters that will support the load and still move freely.
I have all my tools except my on mobile bases. I have the Rockler bases (http://www.rockler.com/product.cfm?page=2383&filter=mobile%20base) under my 8" Grizzly joiner, Router table, Jig saw, and Benchtop planer, - my large equipment was purchased with the mobile base option. (Unisaw, 20" planer, MM16 bandsaw). The Rockler bases have worked well for me, however I do have a pretty smooth concrete floor. These bases have the advantage over many homemade bases in that they have a foot lift that when depressed, allows you to move the equipment on 3 wheels, when dropped the bases set on 2 wheel and 2 feet. Cost is less than the price of 4 good casters. ($49 on sale right now). You do have to fabricate or purchase the wooden "side pieces" to fit the equipment.
