Fixing an old slick
Fixing an old slick
Fixing an old slick
woodenleg
I was given a slick that was beaten and abused without the handle. My question, Can you add metal to the area where the wooden handle goes or I'm I just out of luck? Still lots of chisel left, just not enough metal for proper handle. Thanks, Dave
Re: Fixing an old slick
Bob Hackett
How bad is the socket ? I reforge them if the metal is still there,if it`s not then find one that has the blade used up and graft the socket from that onto the abused one.
Well worth fixing if it`s a top name tool.
Any chance of a pic?
Some choices here. Do you know a welder or do you have a welding machine? I'd ask about blacksmiths, but you may not have one near you. Anyway - yes - you can weld some steel on the socket. You could probably replace the socket.
If it doesn't have a socket, but rather a tang, things would be somewhat more problematic - but I have seen tangs welded on also.
If you aren't doing it yourself, it may be somewhat expensive. You can try brazing on some extra metal or a socket - but welding might be preferred.
New Handle
A. Kapocius
If'n you have a lathe, turning new handles for a socket chisel isn't hard. One method for turning the socket was described by Bill Grumbine a while back. Find a drill size that will fit close to the bottom of the socket with mebbe a little room to spare. Small diameter of the socket is defined by the drill diameter, length of the socket defined by length of drill, large diameter of the socket is measured directly.
Al Kapocius
