200+ woodworking book reviews
OT- Garmin GPS
OT- Garmin GPS
OT- Garmin GPS
Carol Reed, Pahrump, NV
I have a Garmin 1490 LMT and it just quit. Like a fuse blew? Or battery failed? It was plugged in and working fine until I stopped for gas. Restarted the car and the GPS stayed dead. Still dead. Anyone have an experience with these things. I have been googling but not much out there with this model.
Re: OT- Garmin GPS
Jesper, Denmark
Re: OT- Garmin GPS
Jesper, Denmark
No experience with that particular model, but the fuse is usually built into the 12V plug that fits into the cigaret lighter receptacle. It is easy to disassemble, and you should be able to get a replacement fuse at an auto supply store.
If it turns out not to be the fuse, but the unit itself, then repairs are really not economically feasible - new ones are getting pretty cheap if you don't need one with all the bells and whistles.
Re: OT- Garmin GPS
what kind of connection...
Chuck in Mtl.
how is the unit powered...to the cigarette lighter....if yes check this connection carefully. Otherwise the unit may have simply failed. Can you remove it and test it outside of the car with another power supply?
Re: OT- Garmin GPS
Re: OT- Garmin GPS
Doug Adams
Carol
Call Garmin support-- 800-800-1020-- they have been very helpful for me in the past, also if you go to their website you can find the owner's manual for that series and on page 4 there is a procedure for resetting the nuvi. You can reset it by pressing and holding the power button. Has worked for me.
Doug
Re: OT- Garmin GPS
Re: OT- Garmin GPS *LINK*
Jim Dillon
Carol,
My Garmin 12 volt adapter/charger stopped working, although the unit would still charge OK when plugged into my computer via a USB cable. Tried replacing the fuse, but it still did not work. Checked out Amazon and found a whole slew of adapters depending on the model. Price seems to be in the $10-40 dollar range; I think I paid $15 or so and that solved the problem. Found out at the time that failure of the entire adapter is not an uncommon problem. Anyway, do a search for Garmin 12 volt adapters on Amazon and you may find something. Here is one such link for the 1490 model. Good luck.
Garmin Original Replacement 12V Adapter
Re: OT- Garmin GPS
Plug it into your computer
Dustmaker Mike
And see if it will charge. If so the plug went bad. If not I think there is a master reset on it if it is like most Garmins hold the top left side of the screen and turn on the power. It should go into a test mode. You can check battery status etc. you are handy enough to be able to replace the battery search YouTube for instructions.
Re: OT- Garmin GPS
Re: OT- Garmin GPS
Howard Acheson
Call the Garmin Tech service number. They are very helpful and can take over your computer to diagnose GPS problems. They have an 800 number and I have never had to wait more than 15 minutes.
Go to Garmin.com to find the phone number for support. Have your GPS plugged into your computer with the USB cord.
Re: OT- Garmin GPS
Re: OT- Garmin GPS - OK, I think
Well, I tracked down a cable and plugged it into my computer. First I got a green bar at the bottom of the screen and after the bar filled, the comouter said the device was unprooperly ejected and don't do that again. So I unplugged and replugged it in. Another green bar. It filled, The GPS screen now display the logo and a picture of the devise and a CPU. I hope that meanss it is charging. I'm going to take a nap and see what it displays later.
Re: OT- Garmin GPS
Re: OT- Garmin GPS now charged!
The GPS charged through the computer just fine. Tomorrow I will find out if it will charge in the car. The power cord does not come apart to replace a fuse as is shown on various You Tubes. It is molded plastic. The label does indicate that there is a 1A fuse within, though.
We shall see what we shall see.
Re: OT- Garmin GPS
Unscrew the tip *LINK*
Dustmaker Mike
Carol if it is the normal charger the tip unscrews to get to the fuse. If not I think your Garmin can handle the Traffic receiver that is built into the chargers. I have it on my wife's Garmin and she likes it. The cord cost a little more but it works Great in the Mountains of Cleveland(-;
Here is what I am talking about look toward the bottom to see if your area of the country is covered.
Traffic
