How thick should a butcher block be?
matthew
Hi there - I'm looking to make a couple of small butcher blocks for my mother and sister for Christmas. I'll use an incra jig with hard maple and walnut strips. The only wood I could find was 1 x 8. Do you suppose I should glue 2 boards together to get a thicker block - or what size block would you recommend for 3/4" thickness? To be honest, I doubt whether they will see much use!
Thank you!
Ollie
Re: How thick should a butcher block be?
Depends on the application
Bill Tindall
For a presentation application, like presenting bread to the table, or a standing rib roast etc I like a thick block, like 1 1/4" or so. But, for utility food preparation in the kitchen like dicing onions, I like a 3/4 x about 8 or 9" x about 12 ".
Howard Norman
I think that the thickness is a matter of personal taste. I like boards that are between 1 1/4 to 1 1/2" thick myself.
Two things...
David Yoho
You'll want to be careful about using walnut in food prep situations because there are those who are allergic to it.
As far as board thickness goes, although you only have access to 3/4" stock, you can still make a board however thick you desire. Cut strips as wide as you want the board thick, glue these face to face, thus making the top and bottom show edge grain. Edge grain is probably better since it will have smaller pores.
Re: Two things...
matthew
Thanks everybody for the feedback!
Walnut in Cutting Boards
Yonak
Some while back I asked a professor in the Forestry Studies department at the University of Georgia about the use of walnut wood in products that will come in contact with food and of using waste walnut shavings for mulch. He sent me a study done that discounts these concerns as, while juglone, the toxic agent, resides in significant amounts in the buds, nut hulls and roots of the trees (which accounts for the adverse effects on live plants that grow in close proximity to walnut trees) and, to lesser extents, in the leaves and stems, only insignificant amounts actually reside in the wood itself.
His bottom-line recommendation for me was to not worry about it. I, myself, would be much more concerned about the migration of walnut shell pieces after cracking and eating walnuts (in fact, I don't worry about that either) than using the wood in cutting boards.
Incidentally, juglone is not very water-soluble so its migration due to moisture is also not really a concern.
