OT-Building with plastic *LINK*
Tom Dunlap
Of course, this isn't PlasticCentral so my question is Off Topic :)
I've got a plan in my head for building a camper that will go onto a pickup.
Some people are using 2" foam sheeting with plywood skins for their walls and floors. Covering the whole works with canvas then paint. this is similar to airplanes and wood/canvas canoes.
My idea is to use plastic sheeting for the skin and dimensional, maybe round, tubing for the frame. Right now I'm in the 'vaccum' stage...sucking in as much info as I can find.
This has been done and the camping trailer worked very well. The goal is to have a unit that is waterproof and rot proof. Typical campers have lots of seams that leak at some time leading to rotten frames inside the walls.
Since plastic is being used for decks, siding and fences the mfgr. must be engineering the materials for UV degrade. But, sometimes they miss the mark and the materials fail.
Does anyone have long term experience with exterior plastics? I've seen siding on houses that looks saggy or shattered. Maybe that's an installation issue or from a bump. On the other hand I've seen some really straight runs of horizontal fencing too. No sag...so someone must have this dialed in.
The link is to one possible design that I might follow. The camper would be low but have a pop-top or hinge up section to make it a standy. For decades I've used vans for camping so I am too familiar with hunkering.
This is another concept:
http://www.mikenchell.com/forums/viewtopic.php?t=27592&postdays=0&postorder=asc&start=0
If you're interested in trailer building, take a look here:
http://tinyurl.com/Tear-drps-tiny-trlrs
Search for 'Foamies' if you want info on foam sheeting builds.
Pop top
Re: OT-Building with plastic *LINK*
Tom I have worked with plastics for many years - most of the plastics were used to produce interior components for the automotive and appliance industries, but several were used in exposed automotive interior applications.
However, I can state that I have never ever seen any plastic that does not degrade with exposure to the sun. The degrading can be slowed by coating with a metalized or paint coating that restricts or eliminates the UV radiation penetrating the coating. The other method is to use pigments in the molding process that inhibit the depth the UV can penetrate. The fences you speak of normally are made from recycled plastics that no longer meet the strength or other molding specifications of more critical applications (we sold tons of regrind that could not be used in our applications). To verify what I am saying take a look at the automotive junkyards - most of the autos that are over 20 years old have plastic dashes, bumpers, etc that are "brittle" cracked or broken - some have spent most of their lives in garages so that extends the life. I do think you could be successful making such a trailer, however to extend its life you would need to coat the plastic with a high pigment UV resistant paint. I'm not sure a properly designed wood framed trailer maintained to eliminate leaks (and vented properly to promote drying when water does enter the closed spaces) wouldn't outlast a plastic version.
Tom Dunlap
Hi Larry,
Your answer is just what makes WOODcentral such a valuable resource!
A 20 year life for a camper is ancient, even for well built ones. Look at ones like Airstream and Holiday Rambler even.
Maybe framing with plastic tubing and skinning with metal might be the key. The tubing can be used as chases for wiring too.
John McGaw
How about skipping the plastic? You can purchase off-the-shelf exterior plywood with an aluminum skin. I'd think that an layer of this over maybe 1" foam over a thin interior skin would be pretty strong and resilient and aluminum has a proven track record as an exterior material.
Just an idea from a former wanna-be camper maker -- I was going to convert an over-the-highway 40' passenger bus until I started totaling up what the job would cost if done right and decided that my future in camping was more in the line of backpack and tent.
