End grain butcher block finish question
Steve Kirincich
My new kitchen will have an island with a cherry end grain butcher block top. I have been combing the Internet for information, and with an organic chemistry background, I am able to digest the various technical discussions. Mineral oil is not real high on my list, and I am considering either Tried & True Varnish oil or 100% tung oil. I am looking for an option to provide a decent seal against moisture without creating an overly thick, shiney film that will be visibly marked my knives. Thanks.
Steve
Re: End grain butcher block finish question
Some thoughts on your finish.
Any film forming finish such as tung oil, Tried and True Varnish oil is going to "cure" into a relatively hard finish - as opposed to mineral oil which isn't going to cure at all. The problem I have with film forming finishes is that they are going to form a film - a scratch or a cut mark would be somewhat visible. A scratch or a cut mark would "penetrate" the film surface.
My finish for cutting boards is mineral oil and beeswax or Carnuba wax (depending on how hard I want to wipe). I take a crock pot, fill it halfway with water and heat it. I put a steel or glass container containing mineral oil in the crock pot. After it heats, I put wax shavings in the container and stir them in. I keep adding until I get a "gel". Typically I put in maybe 25-30% by volume (though you can put more). Anyway, the mineral oil/wax mixture can be placed in a container for future use (I use peanut butter jars, the glass sort).
You can wipe it on and rub it in. It effectively seals the surface. It is easily renewed. You can even just touch it up with mineral oil and rubbing.
Some other thoughts. Many food service establishments either don't use anything or use mineral oil.
Re: End grain butcher block finish question *LINK*
David Yoho
There always seems to be a great debate on this topic when it comes up. I go with a method I learned from an old professional finisher some time back and it works on either end grain or face grain blocks.
However, I would yield to the folks that make the best cutting boards in the business, John Boos. Check out their Website for instructions on care and cleaning (link provided) and see what you think. They offer two products to protect their boards, which are available through Amazon.
Boos blocks are used by the top chefs in the business. There must be a good reason for this and a good reason why their blocks last so long. I think you can find your answers there.
John Boos Blocks
cutting board theory and experience.....
Bill Tindall
I have owned butcher block counter tops for 41 years. The first 22 years they were cherry and the last years maple. When have them to use, an important point to put the following in perspective. Everything from bread preparation to cutting up deer and sheep gets done on these counter tops. Hence, what follows is a result of practical experience for used counter top cutting boards.
If you use the tops they will self oil to some degree. So, for example, when kneading bread dough that has any oil content, some of this oil will transfer to the top. Scraping(with pastry scraper) the top clean afterward leaves behind some oil. However, after butchering a lamb the tops are scrubbed and this removes oil. Too much of the later relative to the former and the tops begin to look "dry" and cracks at the joints may occur. We find that we have to oil them occasionally. Oil is added and then the top is scraped with a pastry scraper.
With use, the cherry tops will turn nearly black. If you want to preserve the look of cherry varnish them and don't use them.
What to use for oiling?
Mineral oil- easy in, easy out. I didn't find this oil to be long lasting. If used often it could be fine.
Varnish and the like- The other extreme is some film building finish. A film building finish is a bad idea. Working on this surface will cut and scratch it. Pieces will come off and it will soon look bad and be difficult to restore.
So, what would be best is something that is, or would become, more viscous such that it would stick into the wood better.
Fats and Oils- Fats and oils have more or less unsaturation which provides a means of chemically combining these materials after exposure to air to make them more viscous, or even a solid. Linseed oil and tung oil are the most unsaturated and they will cross link to form a film on and within the wood. I find their smell objectionable for a food preparation surface.
The food grade oils have been deodorized and have no objectionable odor. Depending on their origin they have more of less unsatuaration. While they will not form a film like linseed oil they will somewhat cross link to form a vastly more durable result than mineral oil. Used in excess they can make a sticky surface. After treatment the surface must be wiped "dry".
From the composition of the common cooking oils one would predict that soybean oil would react with air to make the most sticky(durable) product and olive oil the least. Walnut oil has also been recommended but I have no experience with it. It is in between the film building oils and cooking oils in unsaturation and hence reactivity to cross link to a durable product.
As a practical matter when our tops look dry what ever cooking oil that is handy gets used to restore them.
The objection to using cooking oil. Every time I recommend cooking oil for wood tops their follows a chorus of objections that the oil will become rancid. While this objection is true, as a practical matter it is unimportant in my experience.
Any oil that has unsaturation, and therefore can cross link, reacts with air to yield low molecular weight acids that stink (the rancid smell of old oil, or curing linseed oil). As a practical matter any top or board that is used is going to absorb fats and oils that will become rancid to some extent. So the real question is whether this result is a practical problem.
In my case all our tops and cutting boards are occasionally treated with some cooking oil in addition to what ever grease and oil they absorb in use. We don't find that the result stinks up the kitchen or food. BTW, many desirable food flavors result from these same stinky acids- bread, cheese, anything fermented or cultured- so the fact that a few molecules of these chemicals transfer from the top or board to the food being prepared is hardly a practical concern.
But if you find the thought of rancid oils on you cutting boards and counter tops objectionable then use mineral oil and don't use them for oily or greasy food preparation. Organic heritage greens will be fine, if grown locally.
Russ, having passed on to the big shop in the sky is still here in the form or Russ's Corner. He had long discussions on finishing bowls. His take was that if your customer picked up a bowl and smelled any finish, they would not buy the bowl as a working bowl. The end result of his discussion was that he recommended Sunflower oil. Its cheap and easily obtainable at the local grocery store. If it has any odor its a pleasant one and unlike some of the others, no one is allergic to it. (Mike Mahoney sells Walnut oil that has been treated to make it non-allergenic.) I have used sunflower oil on many boards and it seemed to work well. I poured it on, rubbed it in and let it stand for hours. Wiped it down and did more coats. It was surprising how many coats it took to fully soak the surface.
Some people don't like mineral oil because its a non food and has been used as a laxative. Not really a problem with cutting boards, but some people object to the connotation.
On my personal boards I have refresh many with olive oil or what ever cooking oil was handy and am not aware of any ill results. Never found any rancid smell.
Also, someone posted a university study that indicated wooden cutting boards disinfected themselves while plastic ones did not.
One point of contention
David Yoho
Bill, you are quite knowledgeable and your advice is always well regarded here. However, I'd have to take issue with one small (or large, depending on how you look at it) point in your reply. It is really just something I think need a clarification in application.
You said -
No argument if a varnish is applied as it would traditionally be when finishing a piece where you want to build a film. However, a cutting board, whether end or face grain, is not and should not be treated like something you want to build a film finish on. All you want to do is seal the pores down into the wood (below the surface).
To that end, I've found great success in using a single coat of Waterlox. I apply a heavy coat to the surface, work it in by hand, and after giving it time to soak in as much as it will, wipe off the excess. This method does not leave a surface film that can leave cut marks in the finish itself or shards of finish to flake off. It simply seals the upper layer of wood and lasts longer than mineral oil and wax treatments. It does need to be refreshed from time to time depending on how much the board is used.
An approach to consider
Bill Tindall
Applying varnish, and Waterlox is a varnish by most measures, as a sealer would seem to result in an initial surface that would have many favorable attributes and not result in a surface film on the wood that would have unfavorable properties. The fact that such an application would involve varnish solvents and dryers is not something that would trouble me.
Thoughts: In use the wood surface will acquire a layer of fats and oils. However, the sealer would prevent their penetration, I suppose. I clean the wood surface with a scraper. Scraping removes much of the surface accumulated oil and grease layer and a trifling of wood. But, perhaps scraping would not be required if the wood was sealed and the sealer hardened. If there is any accumulation of fat and oil would the Waterlox be repelled during restoration?
I like the concept of sealing the new wood surface. I am less sure that a varnish material would be effective in maintaining the surface but I am going to give it a try on my next cutting board.
The advantage of oil is that we always have a gallon of some sort of cooking oil within a few feet of the counter tops. The nearest place that sells Waterlox is 25 miles away and my experience with this stuff is that it does not keep once opened.
Re: An approach to consider
David Yoho
I used to run into the problem of the opened can going bad before it was finished until I started using Bloxygen. Waterlox is too danged expensive to have it go bad so soon after opening and only using part of it. The Bloxygen keeps it fresh for quite a while and I now use it on all finishes I don't use up right away.
Howard Acheson
May I ask why?
An excellent treatment for wooden food preparation surfaces like cutting boards and butcher blocks is a mixture of mineral oil and either paraffin or beeswax. This is what is used on many commercial wood surfaces. It will last longer and be more protective than just mineral oil. Mineral oil can be found in most supermarkets in the pharmacy section or in a true pharmacy. Paraffin is found in the canning section of the store or in a hardware store.
Heat the oil in a double boiler and shave in some wax. The exact proportions are not critical--a 5-6 parts of oil to one part of wax will work fine. Stir the mixture until all the wax is liquefied. Apply the mixture heavily and let it set 10-12 hours or overnight. Next day do it again and continue until the wood will no longer absorb the finish. Let it set for 10-12 hours and then lightly scrape off any excess. Then buff it with a rag.
Reapply whenever the wood begins to look dry.
Never put a wood board in the dishwasher and don't soak it in dishwater for long periods.
Try Clapham's Salad Bowl Finish
I use this stuff for all kinds of things, but it was formulated for woodenware, as the name implies. Near as I can tell, it is an emulsion of beeswax and some kind of oil.
Re: Try Clapham's Salad Bowl Finish
Howard Acheson
Clapham's Salad Bowl Finish is a beeswax and mineral oil mixture. It's easy to make your own.
Steve Kirincich
Thanks for all of the responses. I am leaning toward either tung oil or the T&T varnish. Although film finishes have some issues as noted by others, I think the thinnest of films would best seal the porous endgrain. My wife absolutely loves the look of a large endgrain countertop with 2.75 inch blocks, and if we use cutting boards for the bulk of our chopping, I think we can strike a balance between functionality and surface preservation. The countertop will be made by Krug & Ryan. Check their website for some nice but pricey cutting boards.
Steve
Practice first, what ever you decide
Bill Tindall
Since the purpose of this surface is to look at how it will look rather than how it will wear as a butcher block has become the most important consideration. Things to consider.....
Pure Tung oil takes a long time (days to weeks)to cure. I put some on a knife handle two weeks ago and it is still sticky. It does smell better than linseed oil which dries faster. (Things sold as "Tung Oil" finish can be simply varnish with a whiff of tung oil as an oil component.) Oils will darken the wood and it will get darker over time as the oil oxidizes. Try it on a piece of end gain cherry to see that the result is what you want. Our oiled (animal and vegetable oil) cherry tops became so dark over time that one would not have known they were cherry. Once the oil soaks deeply into the end grain if the result is not what you want you will need to pane the surface to get back to unaltered wood.
Thinned and used as a penetrating sealer any varnish is likely to perform the same. The main advantage of T&T varnish is the ease with which it can be applied because it takes a long time to dry, a benefit for a spool bed, greatly less so for a flat horizontal surface. If I was going to go the varnish route I would be trying any handy varnish that was light colored. The urethanes are hard and durable and some don't darken much. Thin it till it is watery (something like 3 parts varnish to 1 part thinner) flood it on and wipe the excess off. Lightly sand and it's sealed, smooth and the appearance should remain about the same over time, but with some darkening that cherry normally shows. Since you are not going to cut on this surface and no surface film will be built up, a varnish-sealed surface can be easily renewed at any time by light sanding and repeat thinned varnish application.
I have the feeling that you have seen something that you are trying to replicate. In such cases practice on test pieces can save a lot of disappointment. Things to experiment with beyond initial looks are the response of the surface to washing, whether grease spots soak in and form an objectionable spot and any other vicissitudes you expect the surface to encounter. The top manufacturer may have a recommendation.
jerry roberts
I used some Clapmans on three cutting boards I have made for Christmas. I like the stuff a lot and it doesnt take much to look good.
