Unisaw motor update
Unisaw motor update
Unisaw motor update
John in NM
Got my new motor Wednesday, finally got it installed today. Replaced the 1 HP repulsion induction motor with a 2 HP capacitor start motor. Steve Schoene had it right, bracket fit fine with a little tweaking, but the motor almost required modification of the saw cabinet.
The junction box on the new motor was bigger than the old, and on mine that's what was hitting the cabinet at full blade height and as the blade was tilted. Got lucky though, I was able to use the smaller junction box from the old motor with just a little grinder work to accommodate the tighter curve of the new motor.
A 3 HP motor would have definitely required cabinet modification, as the spec sheet shows the motor being 1" longer than the 2 HP.
The interesting thing about that old motor is that it ran at 1725 rpm instead of the now standard 3450. While the slower speed effectively halves the horse power, but doesn't really affect the unit force per tooth, I expect performance to be about the same. I am looking forward to the faster blade though, I always found this saw "grabby" on plunge cuts and similar goofy things that one shouldn't probably do anyhow :D Fortunately, years of using it has gotten me out of doing such cuts, but I'm interested if I notice a difference in other ways.
Re: Unisaw motor update
Brian
gotta change your pulleys when going from 1724 rpm to 3450 rpm. slinging the blade at double speed. may explain the "grabby" experience. cut the cabinet if needed. who cares? it's a table saw not a jag or vet or porsche. i did all sorts of non-original mods on my 50s vintage unisaw including wacking the cabinet opening for motor. don't use it much but when i do i'm confident it's within accepted standards.
Not a question of originality...
John in NM
Cutting the cabinet seemed like more work than swapping the boxes, which only ended up taking 10 min or so with the modifications.
Alan in Little Washington (NC)
I'm not sure what you mean by
"The interesting thing about that old motor is that it ran at 1725 rpm instead of the now standard 3450. While the slower speed effectively halves the horse power, but doesn't really affect the unit force per tooth"
The old motor was rated at 1 hp, not because of the RPM. Service factor aside and as long as you are not changing the speed (of a 3 phase motor using a VFD) a 1725 RPM induction motor rated at X horsepower will yield the same power as a 3450 RPM motor rated at X hp. If either is geared up or down via pulleys they will still generate X horsepower though the torque will change. No matter how it is geared, a 1 hp motor will still generate 746 Watts or 1 hp.
you are correct
John in NM
I hadn't considered pulley size. Oh well :D
Re: you are correct
I don't know what the blade speed on most tablesaws is, but it seems to me that if you doubled the speed of the motor, either the blade was running "too slow" before or its running "too fast" now. Those being relative terms and it is possible that whatever the sped was and is, they both might be within acceptable ranges, but there might be an upper limit that is recommended for blades and that if you exceed that, a blade could fail catastrophically. Might be a good idea to check out the situation and see if you have exceeded the limit. It would be a shame to ruin a perfectly good saw blade in an act of suicide.
Not exactly the same thing, but I put a thin abrasive cut off wheel on my chop saw. Blade was labeled for 5000 rpm. (I had ten of them) Looked a little spooky to me so I put on my suit of armor. (A heavy jacket, coveralls, eye protection, a face shield, and gloves.) Tried to carefully cut a rebar. The blade exploded and pieces of shrapnel hit me. I took off the armor (I was really happy about that silly looking suit), threw the pieces away along with the other nine blades and cut the rebar with my Sawzall.
Planning to find a new pulley
John in NM
After the discussions here I did some digging and I'll order a smaller pulley.
Re: Planning to find a new pulley
del schisler
Doesn't the speed with a 3450 rpm motor with a 10" blade run a 1:1 pulley? I would get iron pulley's if it were me. I used browning brand which are top of the line. Just my thought's and 3 cent's worth inflation you know
Yep, 1:1
John in NM
The older motor used a 5 1/4" pulley, about 1:1.6
RPM comes out to 5,500 or so with the larger pulley, within the specs of most blades I have (those that are still marked :D ), which list a max of 6,000 RPM. Still going to change the pulley and buy new belts (shorter of course), there's a bit more vibration than I like at the higher RPM
I'll look for that brand of pulley, I found a couple OEM parts but its always good to have options.
