what kind of epoxy?
what kind of epoxy?
what kind of epoxy?
McKay
I am making two workbenches for my two sons and need to fill some holes in the re-claimed maple that I have made the top from. The maple is from work benches from a torn down school. There are holes in the top that need to be filled. What kind of epoxy do I need to get to get a good hard fill for these holes?
TIA
Re: what kind of epoxy?
Bart Goldberg
Bart Goldberg
Generally, the slower setting epoxy will harden more than faster setting epoxy. If the holes are large, there are fillers you can get that will help to increase volume to fill large holes. There are also micro fiber fillers that will increase final hardness it that is a concern.
Bart
Use Bondo
Bill Tindall
tip I got at a professional cabinet shop in Berea , KY
If the holes are small...
John in NM
A quality 5 min epoxy will be ok. I like the stuff from Pacer that I buy at Home Depot for nail holes and small blems. It has the added advantage that you don't need to buy a huge amount. As Bart said, longer drying times will generally give you harder epoxy, so you could look for some 30 min or greater at a hardware store or better yet a hobby store that supplies RC modlers.
Bondo is ok for small areas too, but I've found that it doesn't adhere as well as a lot of other products. I don't know if it's the type of resin used or that it is about as cheap as resins get, but I generally don't use it if I have other options available, which I usually do. It does beat the heck out of most of the "wood dough" type fillers though, I'll give it that. I would bet that if you could find a non-Bondo branded polyester resin, it would cost twice as much and stick a lot better :D
Best stuff I've ever used is a urethane resin, but it's expensive and has a very short shelf life, so only good for a filler if you have it around for other uses (which I usually do). West System 2 hour epoxy is a close second or a tie - not quite as good in properties, but doesn't go bad in a couple months :D
I fill a lot of nail holes and other problems on my turnings. I just use regular old 5 minute epoxy that comes in the syringes. I do add some color to it for nail holes. Sometimes it's just the sawdust and sometimes it's any colorant I have handy. If the nail holes have dark discoloration around them I just use black shoe dye or a little black acrylic paint.
Clear doesn't look bad for that kind of hole. If it's a small hole I might just use some of the sanding dust for that wood. larger hole tend to look like you plugged them with pressed wood, not good. For the larger holes I prefer a contrasting color to the wood, either black or something really outrageous like turquoise or silver.
I have used copper pipe. Sand some of it on the disc sander and then pick up the dust and stir it in the epoxy. A quick reminder. A piece of copper pipe gets really really hot really really fast when you do this. I threw it across the room the first time. use protective gloves. :)
Dick Coers
I vote for filling with wood. If the holes are smaller, sharpen a dowel in a pencil sharpener, then add a little epoxy and drive it tight. Bigger holes, bigger dowels. You might also consider using a router and inlay kit to be able to patch with face grain plugs. Depends I guess on how you use the bench top, but a nick in mine is a big deal. I treat it like a fine tool.
Brian Anderson Gunsmith
I would have to vote for the use of a solid wood piece held in place with epoxy or wood glue.
No matter how hard you work at it, I find that I cannot keep the epoxy completely level with the surface. Epoxy is Epoxy not wood so it will not move the same way that wood does.
What I would do,....
If I had a workbench.....
Use a plug cutter and make some plugs out of matching scraps. then drill a hole in each defect that matches the size of the plugs. Use a cotton swab and slather a little glue in the hole, roll the plug in the hole, tap it in with grain aligned. Leave them proud and sand them to submission.
Me Too
