How to Cut a 1/16" Groove?
Tom MacGregor
The adjustable sill on my new exterior shop door may have looked like wood from a distance, but proved to be cheap plastic the first time I rolled something heavy over it. I'm reproducing the broken part in hard maple. It requires a 1/16 inch wide slot for the weatherstripping, but I don't seem to be equipped to cut less than 1/8 inch wide. Even Dremel only lists cutters down to 1/8". Anyone have any suggestions?
Re: How to Cut a 1/16" Groove?
Re: How to Cut a 1/16" Groove? *LINK*
Jesse Cloud
If you need a stopped groove (not all the way through), then use a router bit.
If you can plow all the way through your stock, then the thin Freud bits that Bill Tindall likes cut close to 1/16th.
1/16th router bit
A blade for a portable circular saw, (Skilsaw) would probably do that. Mount the blade on your TS.
Also, you can buy wing cutters for a router. Little two or three wing cutters (sort of little saw blades) and you can get them that thin easily. They mount on a mandrel/bit. Once you have the mandrel you can mount almost any thickness cutter you might want. They cut parallel to the base of the router and may not have enough "reach" for you. Not sure how long a shaft you can get.
saw balde
Bill Tindall
There are saw blades that cut a 1/16" kerf. In fact I normally have one on my saw.
AZ in Colorado Springs
If the other suggestions don't work satisfactorily in a hard wood, then you can cut a 3/8" groove and add back a 5/16" filler.
Make the part wider than you need, cut a 1/8" groove with your table saw. Then rip in in half leaving the 1/16" kerf and glue it back together. You'll probably have to wipe the excess glue out of the kerf but that should be easy with a piece of short cardboard or something similar.
My father made a sliding window for our bathroom some years back, using little rollers on the bottoms of the sash, running in hard maple tracks. The tracks lasted about two years. Maple's not a durable wood in the weather - if exposed to water, it'll rot. If this portion of the sill has ANY weather exposure, I suggest you rethink the use of maple. White oak's probably the best easily available hardwood for exterior use - but make sure it's white, not red, oak. Ipe might be another possibility, although I understand it's hard on tools.
red oak is ok
Bill Tindall
All the commercial sills in my house are red oak. I have a 20 years old red oak gate that is still fine. I agree on maple. In fact any sap wood from any species is not durable exposed to dampness.
