Kayha plywood question
Mark
Does anyone have any experience using this? I am told it is a mahogany substitute. Does it stain up similar to mahogany ?
Thanks
Mark
Thanks
Re: Kayha plywood question
Thomas S Stockton
Mark
Khaya is also called african mahogany it does look similar to genuine or honduras mahogany but it is not an exact match. In other words if your trying to mix and match the two species on the same piece it's probably not going to work, but if you use just using khaya it's going to look close and should work. 1/4 sawn it looks really nice.
I think it is a good substitute my only problem is that it can be hard to find good quality solid stock and the solid tends to move more than I like.
Tom
Bart Goldberg
If matching to Mahogany is your goal, why not just use Mahogany ply in the first place. However, even then, you will not get an exact match as the ply veneer will stain different then solid wood in my experience.
Bartman
Mark
Thnx can't find anything but African M. Trying to get a dark brown col ur versus reddish tone ...
Thanks
African Mahogany Alternatives
Bart Goldberg
Mark,
Why not just go with Walnut if you desire a Brown color.
Walnut is plentiful and relatively cheap and Walnut ply is readily accessible
at several local lumber stores. Also, no need to stain it.
Bart
where are you at?
Bill Tindall
I have several sheets of Mahogany plywood I want to sell. I am in E. TN.
