Finish for Spalted wood Question?
My son (with a little help from his male parent) has built a Krenov style cabinet out of spalted maple. The color is very appealing the way it is, but we sprayed a sample with lacquer and it darkened it considerably. Is there any finish that won't darken it or at least darken it less?
Re: Finish for Spalted wood Question?
frank ashmore
water white lac. goes on real clear and doesn't change the woods appearance
While anything (including water) will darken the wood somewhat, I prefer to use ultra pale dewaxed shellac as a base sealer on spalted wood. Apply several light coats of 1 lb. cut, about 2 hours apart, to even out the porosity of the spalted areas. After 4 hurs, sand very lightly with 400, then apply a last coat of the same shellac. Allow 24 hours to dry, rub with a fine (gray) synthetic wool pad, vac off, then apply a water-white waterborne finish like General or Target. The shellac will prevent the grain from being raised.
Re: Finish for Spalted wood Question? *LINK*
del schisler
yes their is if you use this blotch control the wood will stay the way it is. Now if you stain any wood than this is the stuff to get. I use it on all my wood item's that i build. It is mfd. by charles neil here is the web site it is a video u tube he has lot's of other item's also
http://www.youtube.com/profile?user=InTheWorkshop#p/u/36/IfCYMdrP8rM
