OT-Fireplace Damper Handle
Steve in Phoenix
My house was built in 1974, and the fireplace has a traditional rectangular damper. There is a bar welded to it with a hole to use the fireplace poker to open and close it (which is quite awkward). I would like to be able to open and close the damper from outside the fireplace, as well as be able to control how much it is opened.
I have found handles online: http://www.chimneysupply.com/docs/prod.php?grpid=3&subCat1ID=7
But I just cannot visualize how they work. I assume I would need some sort of slot to slide the handle through welded to the metal plinth that supports the top of the opening?
Any links, photos or advice would be much appreciated!
Re: OT-Fireplace Damper Handle
George Koch
Steve, all the dampers shown on that website appear to be the type to operate the damper from inside the firebox and the one I believe your looking for would have to protude through the masonry face. The one I'm familiar with is a worm drive gear attached to a square rod. I would suggest a trip to the local mason supply store and explain to them what you looking for. We use to order that add on accessory when ordering the original damper and the mason would have to install it when building the fireplace. George
Here's how they work
The damper handle goes through a steel fitting welded to the underside of the lintel. The far end of the handle bolts to the ring on the underside of the damper. The handle has teeth that engage a matching tooth in the steel fitting.
If your damper has a ring on it, and you have the fitting welded to the lintel, all you need to do is measure the distance from the fitting to the ring in open and closed position, and then get a handle whose teeth span that range.
When in doubt, call a local chimney sweep and let him figure it out.
Re: Here's how they work
Steve in Phoenix
Thanks Ellis. I'll need the ring welded to the lintel to make this work.
But I am a little embarrassed about confusing lintels and plinths!
Steve in Phoenix
I like your idea, and I could likely fabricate what is needed in the machine shop. But my wife blanched when I suggested we needed to drill through the front of the fireplace. She wins...
