6 V vs. 12 V lamp wattage
Al Stokka - Cambridge, Iowa
Howdy,
I need help comverting a light bulb. The application doesn't matter. Well, OK, it's a proofmeter (combination tachometer, speedometer, and hour meter) for a tractor. 8N Ford tractor to be exact.
The replacement tachometer came equipped with a 12 Vdc, 2 watt lamp for backlighing the face of the tach. My tractor, being the PROPER 6 Vdc, will not light the 12 V lamp properly (I assume. I haven't tried it and don't intend to until I change the lamp.) so, I need to know what wattage 6 Vdc lamp will produce the same light output as a 2 Watt, 12 Vdc lamp?
I don't want to use too high a wattage lamp because I fearful of the extra heat buildup in the tach enclosure, but I don't want too low a wattage lamp and rish note being able to read the tach.
If you'd care to share the formula, that would be a plus and I'll attempt to remember the formula but, at my age I won't make any promises. ;^)
Al
