Analine Dye Question
Robby Wright
I am making a calendar holder for my wife. I plan on using analine dye dissolved in water for the staining, followed by shellac for the finish, probably sprayed. Because it would be difficult to knock the fuzzies off after staining, I would like to pre-stain some of the parts before glue-up, then lightly knock of the fuzzies with a very fine synthetic abrasive pad and glue the frame pieces to the backing. I will be using the damp wet-down procedure to raise the grain before staining, but it has been my experience that I need to do that last little bit to get things really nice after staining.
So, can I glued to a surface that has been stained with analine dye? I plan on using Titebond III, my favorite glue.
Thanks in advance for your help.
Re: Analine Dye Question
Dick Coers
I've never predyed some parts, then dyed other parts. My concern would be that some parts will have two coats of dye, others one. You better try this on scrap to see if you get different dye intensities based on number of coats. My thought would be that the glue will work fine, but never done that either. All in all, not much help am I, sorry!
JMOHNIKE
If you are going to pre stain/dye why not pre finish those parts as well? I would think that by doing so, it would make glue squeeze out clean up easier and also help remove the double stain/overlap problem. Just a thought.
Steve Schoene
You can knock the fuzzies down after you have applied a coat of shellac. The shellac hardens the raised grain and makes it easier to cut off with 320 sandpaper.
I wouldn't worry about gluing to dyed surfaces, but I would want to dye all the parts at the same time. Dick hit the nail on the head. If some parts that have dried get touched by a second dye coat they will darken considerably. You could fix that, but that process would be essentially the same as dying the whole piece after gluing.
I usually prefer to dye after gluing. Yes, you have to avoid glue squeeze out issues, but gluing first allows you to "adjust" any surfaces that don't end up entirely flush, etc. It is a PITA if you have to match dye on a surface where you have had to sand or plane off a bit to get the match up right.
Robby Wright
No matter how carefully I try to word it, I always leave it open for two interpretations.....Grumble. My intentions is to stain everything first, then knock the fuzzies off, then do the glue-up, and finally shellac the thing and give it to my wife - hopefully to some smiles. Phew!
Thanks for your comments.
