How to clean a grungy antique?
DouginDenver
I bought a couple circa 1880s mahogany picture frames last weekend that are not stained and have some sort of thin film finish on them. I think they will have a nice patina once cleaned, but they are real grungy with 130 years of dirt on the surface - a little too much patina. Two questions:
1) What is best to use to clean the surface? A slightly damp cloth turns black real fast, but I think I need something to help cut and lift the dirt.
2) What finish is an 1880s frame (presumably American) likely to have? Shellac?
Thanks.
Re: How to clean a grungy antique?
Re: How to clean a grungy antique? *LINK*
Stuart Johnson
Murphy Oil soap has worked well for me. Take a look at the "wood care" and "for the pro" tabs on the link for how to use it.
Murphy Oil Soap
JMOHNIKE
Keep useing the damp cloth, as long as it keep turning black you are removing the dirt. There is a good chance the black is suit from oil lamps and candles. Allow the frame to dry between wipe downs. When the cloth nolonger removes any dirt, check the frames for any other deposits. If there are any use a Q-tip dipped in a weak cleaner (less is better)and work only on those areas. To find out what type of finish, look at the back of the frames for any finish that may be on the back edges. Again using a Q-tip dipped in alcohol rub on any that you can find. If it desolves then it is more than likely a Shellac finish, if it not removed then it more than likely a varnish of some type. Good luck.
Steve Schoene
You can add a couple of drops (literally no more than that) to a couple of quarts of water. The soap will break surface tension, but not create a sudsy solution.
There is a very large chance that the finish was shellac. Various oil varnishes were available in the period, but wouldn't be likely choices for finishing frames.
Al Stokka - Cambrige, Iowa
Doug,
The late Sam Simpson posted this recipe March 8, 2006:
American
8 fl oz Pure turpentine
4 fl oz Denatured alcohol
2 fl oz White vinegar
1 fl oz Murphey's Oil Soap
1 fl oz Brasso
1 tspn houshold Ammonia
English
200 ml Pure Turpentine
100 ml Methylated spirits
50 ml Acetic acid B.P. (33%)
25 ml Teepol (liquid soap)
25 ml Brasso (metal polish)
5 ml Ammonia .088
Al
Oops! March 18
Cream Hand Cleaner
David Yoho
Many years ago I took a tip from a professional restorer from a book he wrote and it's worked perfectly each and every time I've used it. I figure this fellow knew what he was doing since his resume included work on furniture belonging to James Monroe.
For most antiques, the original finish can be revived by simply cleaning with DL® Permatex® Blue Label™ Cream Hand Cleaner. I apply it, let it set a bit, and wipe it off with freshly dampened cloths. After the surface dries, I apply a coat of paste wax and buff. There are reasons the Permeates brand was used over others but I remember the warning to only use this exact product. All I recall is there was something about the solvent used and there was no abrasive quality to the product.
Bottom line - It Works!!
You should be able to find it at Auto Zone and other automotive supply stores, as well as paint stores like Duron Paints.
Steve SchoeneIt's
I can't imagine using that combinations on antiques. The most likely finish on antiques is shellac. Alcohol will dissolve shellac. The ammonia is also a true solvent for shellac, but it won't evaporate away leaving the shellac behind. I suspect the result would very nearly be a stripper for many antiques. Yes you might get a dramatically "cleaner" looking piece, but if it had value as an period antique it could be significantly impacted. Don't use it.
Re: Cream Hand Cleaner
Carol Reed, Pahrump, NV
I got some of this hand cleaner today. I picked up an old white oak kitchen table I need to clean up and likely will need to apply a new finish. It is pretty grungy so the first thing is cleaning it. The pedistal especially looks like it is really dry and in need of finish.
So, David, how much of this stuff do you apply and any other details/techniques you'd like to share? Thanks.
Re: Sam Sompson
Al Stokka - Cambridge, Iowa
Steve,
I can't entirely vouch for the quality of the cleaner that Mr. Simpson posted. But, as I recall, Sam worked for many years as a conservator in a museum. It was then that he came up with the recipe. I've reposted Sam's formula a number of times (6 to 12?) since Sam's death and have not heard or read any complaints. I'm open to haveing my memory questioned and/or corrected.
Al
David Yoho
Carol, there's no real guidelines to using the hand cleaner. If a piece is very dirty, it may take several applications to get it clean.
I generally just slather it on and give it a little time to start loosening the crud. In the past I've applied it using several methods, which were dictated by the surface it was going onto. I've applied it with my bare hand to flat horizontal surfaces, with a white Scotch-Brite pad, and with a cheap paint brush for surfaces that are irregular or carved.
I like using the white pad as an applicator and to work it around in a scrubbing-like motion. The white pads contain no abrasives but their texture aids in loosening the dirt. Another possibility is a short bristle brush. This is great for cleaning irregular surfaces and getting into all the nooks and crannies.
Wipe it all away with an old cloth or I like to use a big sponge.
The author once told me that I'd be amazed at how many times a client called him out to strip and refinish a valuable antique only to hear him say it didn't need it. He simply cleaned the piece with the hand cleaner, maybe performed a few minor blemish fixes, and then waxed it. I can report it has happened to me, as well, and the clients were very happy with the savings between stripping and cleaning, not to mention how good the piece looked when I finished.
Re: Sam Sompson
Howard Norman
Al, I have made and used Sam's cleaner several times over the years. It has always worked for me. The first time that I used it was when Sam originally posted the formula.
howard
Re: Sam Sompson & shellac
Howard,
I'm pleased to hear the confirmation. I have faith in Sam's opinion and don't recall him ever warning that it shouldn'e be used on shellac.
Just wondering if you might have used Sam's formula on shellac?
Al
Howard Norman
Al, I can't say for sure if I have used Sam's formula on shellac or not. If I did it was several years ago. I have used it on several finishes as I recall and never had any problems.
Howard
I would bet you could skip the acid+base
John in NM
Vinegar and ammonia will for the most part neutralize each other, leading me to wonder why one would use both in such a mix. I suppose the salt resulting from their mixing might have some use in cleaning, but I suspect the answer is more along the lines of hocus-pocus mix all this stuff that might clean something alchemy. On the plus side, the vinegar should keep the ammonia from damaging any shellac :D
