Wayyyy OT: electric razor
Pat Evans
I purchased a Braun battery powered razor to save on water while RVing. However, at my age my beard is more white than black and the white hair is thinner and softer than the black. The Braun simply won't cut the white hair. It just pushes it over.
Any recommendations on a battery powered razor that actually works?
Re: Wayyyy OT: electric razor
I have a Braun and don't have any problems. In fact the reason I shave is my beard is more white than black and makes me look older. It shaves the white hair with no problems.
Stuart Johnson
Norelco or the Remington look alike. I've been fortunate to have light (thin) whiskers to the point I use to change razor blades once a month whether needed or not and they both work great for me. FYI, shave with the grain not against it and you'll get a closer shave.
Isn't this board great. We can obtain all of the woodworking help possible plus a thread on $12 to $20 dollar a pound coffee and now electric razors. What happened to beards and McDonalds senior coffee?
Agree Stuart:  Brains as well as Braun
I've had a Braun Series 5
Mike Farinella
for about 4 years now. Yes, the white ones are a little difficult sometimes. You must stretch the skin for the razor to work.
I also have a Norelco and a Wahl. Junk by anybodies standards.
I put some water in the sink and soap up/rinse my double-edged razor in that - probably a pint. Do you need to be more abstemious with water than that?
Can't help on the 'lectric razor question. I don't like them, never felt they worked well enough to use them.
Abstemious? yes
Pat Evans
We dry camp and really dislike having to dump or get fresh water. Every drop saved helps. We can usually make it just over a week on 50 gallons, but that includes bathing every day.
Yonak
My Braun has a doohickey that has two pop-up settings for getting the stray whiskers. Setting one shaves and trims. Setting two trims only. Myself, I have never had luck shaving with the grain .. especially trimming.
Re: Way OT: electric razor
I have been using a Norelco for many years. It works well unless you skip a few days. Get one of the top of the line ones, They work better than the cheaper models.
There You Go!
George Colonel's Workshop-Havertown PA
Good Evening Bill,
My absolute favorite was a double edged razor by Gillett. I don't have it now, as it was disposed of by an over conscientous hospital cleaning staff. It belonged originally to my Dad, and I carried it all over the world. I still lament the loss. I'd buy another one if they and the blades were available here.
George
