Re: Another Vac Veneer Press question
TomD
Yeah, the forces run wild at the edge of the veneer. The veneer at a point one inch in from the edge has the atmosphere pressing down on it, and effect of all the veneer around it being pressed down also. But at the edge, the loads are only bearing down on that point, not the point outboard of it.
With 25" of Mercury, this should not be a problem. I have done boats where the vac pressure was 2 pounds, but the materials were limp sheets of plywood about 1/8", and flat and parallel. These will normally be fine right out to about 1+ inches of the edge. That could be regarded the inherent condition. So with about 12 pounds in your set-up, one would expect the edges to go down, and normally be fine with veneer also. But there are no guarantees.
Materials like impregnated cloth, are pretty much zero resistant, but wood, whether thick or thin can be very difficult to flatten. Birdseyes are the classic. These dry into little arches and can require a lot to flatten out. At this point it becomes simple mechanics. You can use cauls, edge cauls, additional force, like clamps or weight, oversized pieces; Whatever. Another effective technique is to use thickened glue. With the boats, normally I just let the materials run a little wild and trimmed back. But occasionally there would be a part that came right up to the edge, sometimes I would add glue later. But if I could anticipate the problem, I would use the white glue consistency epoxy over most of the sheet, but pre-treat the critical edge area with some glue thickened with Collodial, and micro balloons. This would be thick enough to hold even though there was not sufficient vac pressure. Not sure what products would work that way with cabinet grade glues. If you are using poly glues, there are compatible caulks, not sure about the whites and yellows. But one never knows when a technique will come in handy.
Another option if your materials are a little closer to perfect is to lightly moisten the materials on the outside. The inside is getting wet if you are using any of the common water based glues. There is not normally that much risk moistening the outside. This may soften the material enough to flatten it, but not likely with 1/8" solid wood.
