Furniture?Veneer repair questions
My cousin has a chest from about 1984 made by Henredon (SP?). A nice piece of furniture. The veneer on the drawer fronts delaminated when the chest was about five years old. In some cases its the pulls holding the veneer on.
So, Does anybody know what Henridon would have used for glue?
How do you repair this?
Re: Furniture?Veneer repair questions
George Colonel's Workshop-Havertown PA
Good Afternoon Barry,
Test to see if it was a liquid hide glue originally. If so, it can be reactivated, and reused. Clamp securly. Squeeze out can be readily addressed with a damp cloth.
If not liquid hide glue, I'd use Titebond. Assuming you have all the veneer intact and that it is already seperated from the substrate, I'd remove the glue from each surface with careful light sanding, and insure a level surface. Then evenly apply the white glue and clamp the veneer in place.
I've also had to repair veneer which was partially separated from the substrate. I used liquid hide glue applied into the rift with an artist's brush, clamped and wiped with a hot damp cloth.
George
