Good luck with the vacuum Press....and Questions
Followed the advice below and on Joe Woodworker and put together a bag and the connections to my pump.
Used it twice yesterday. Very pleased with it so far. Put the things in the bag and turned on the small gast pump. The gauge indicated it went to 20" and then slowly rose to 25". Left it for about forty five minuted and then turned the pump off. It held vacuum for over an hour, slowing leaking down to about 10". When we opened the bag, it went pssschow or however you spell it.
Getting the glue right remains a problem. Trying to judge "just right" is the problem. Too much has problems and so does too little. My son was clearly slathering on too much. We will be using white glue. Any suggestions? How about a finely notched trowel?
Anyone tried the mesh Joe Woodworker promotes?
Do you usually use cauls or just let the bag have its way. What do you do about sharp edges in the bag.
Re: Good luck with the vacuum Press....and Questions
Bill Earl
I really like the powdered "Ultra-Cat" adhesive that Joe sells. Even if it does bleed through (an unavoidable problem with some burls) it sands well - unlike the PVA glues.
Bill Tindall
Jeff Headley applies glue with a brush. So do I but if I get too much I scrape it off with a home make "toothed trowel" made by filing tiny vees into the edge of a credit card, or actually motel key card.
Dick Coers
For small work, I use one of those glue bottles with a rubber roller. (Made famous by Norm) If doing larger work, the right density foam roller works the best.
http://www.vacupress.com/accessories.htm#foamrollers
Foam roller for glue
John in NM
The little 4" ones you can buy at any hardware store. Quickly puts down a thin even coat of glue. Haven't tried with white glue, but they work great with plastic resin glue.
While I don't doubt that PVA's work fine for wood veneer, I've seen lots of problems with bubbles using the paper backed veneer. Might have been operator error, but it might be something about the paper.
Re: Foam roller for glue
jcousins
i use a small notched plastic trowel that i purchased from joewoodowrker for laying out the glue - i primarily use unibond and always thought that i wasted too much in a foam roller. bought i years ago and don't know if he still offers it.
for the edges i usually take a coarse rasp to ease them - especially the corners.
jerry
Jesse Cloud
Congrats on your success! How about some pics??
Is the issue with too much glue that it is bleeding thru the veneer, or just that it is messy? If messy is the issue, use a melamine caul and it will scrape right off.
The mesh Joe sells is great for curves. I use two melamine cauls for flat stuff. They need the edges broken or you will get a leak in your bag.
I use my tablesaw set with the blade only 1/8th high to make kerfs in the cauls to allow the air to escape fully from below the cauls. If you are having problems with bubbles in the veneer, try this.
Have you tried taping together smaller pieces of veneer? Joe's website covers it and that opens a lot of doors!
