Have a question? Ask Woody!
Machinery find ( Rockwell Model 10 Table Saw )
Charlie Lenz
For the people that know me, you guessed it, I found another Contractor's Table Saw. It's a Rockwell 34-410 Model 10 Contractor's Saw. I got it pretty much complete with the flared leg stand, miter guage, the less then desitable Micro-Set fence ( Chrome round tube rails ),stamped steel wings, and original motor. But since I allready have two saws, this one I'll be fixing up and selling. It appears to be in fair shape, but when I turn it on, there is a timed knock. Either the arbor pulley is too close to the arbor houseing, or an arbor bearing is out, I'm not sure yet. I did gab the arbor, and can't feel any play in it, so I'm hopeing that it's a good sign.
Re: Machinery find ( Rockwell Model 10 Table Saw )
George Colonel's Workshop-Havertown PA
Nice Find Charlie,
I'm looking for a good contractors' saw for my #2 son, who presently uses a Crapsman 10" direct drive screamer. Wish I had a million dollars so I could afford a few good used ones to bestow. There is no lack of good machines available, maybe enough to supply each of my kids. But the prices!!!!!! Both kids and saws tend to be expensive. :(
George
Re: Machinery find ( George )
Charlie Lenz
Trust me George, I picked it up at a very affordable price. Now we will see how much time I'll have into cleaning and adjusting. The blade is out of paralell to the miter slot by about a 1/16 of an inch, and then the ticking issue. I'm just going to do what it takes to get it back into shape. If I was to keep it I could easily throw $300 plus more into it with a link belt, T2 fence, mobile base, paddle switch, and dust hood. It adds up fast, but it's nice to have an American made machine.
I have the Delta Rockwell version of that saw I have had for forty years. I am entirely happy with it and can't think of a single reason to upgrade. That's a nice score.
timed knock
Dave Bair, Eaton Rapids, MI
If you're lucky, the knock is from the old belt taking a set around the pulley.
Re: timed knock
Charlie Lenz
I hope your right Dave, but it sounds more like a mechanical knock when I turned the blade by hand.
Charlie Lenz
I agree Barry, I've had a Delta 34-444 with a Unifence since I bought it new in 1995, and I also can't think of a reason to buy anything else. For a few years I had it wired up for 115V, until I had the garage/shop rewired, then I wired the saw for 230V. No more dimming lights on start up, and no triping breakers on tough cuts of thick hardwood. Thats not to say that I couldn't of got the same results at 115V. The 115V outlet that I was useing had other outlets, and obviously the lights on that same circuit. A dedicated 115V circuit, meaning a single 115V breaker powering only one outlet. A 20 amp 115V dedicated circuit probably would of worked just fine. But while the electrician was rewireing the shop I just let him decide the best way to go. Anyway, now I'm a little more aware of what I plug my machines into. The dust collector, and air compressor are now on their own 230V circuits. Folks if you think that your Contractor's table saws are under powered, it may just be because of what you've got the saw pluged into, and or your blade is dull.
Re: Rockwell Model 10 table saw timed knock
Charlie Lenz
Well I had a chance to look over the arbor a little better today and discovered the culprit. There apparently is a spacer that fits over the arbor shaft and is between the arbor bearings. For some reason it is loose on the shaft and is supose to fit tight, atleast it does on a Rockwell 9" Contractor's table saw that I compared it with. I also noticed that on the 9" saw the spacer fills up the whole space between the bearings, on this 10" that I just bought there is about a 1/4" gap and I can slide the spacer from side to side. My best guess is that the bearings aren't seated all the way in. Hopefully tomarrow I can do a little more investigating.
Charlie Lenz
I got the arbor mechanism removed this morning, and I suspected, someone I think replaced the bearings but didn't get the blade side bearing seated all the way into the houseing, Now the spacer between the bearings fits tight and doesn't rattle. But I need to get a new arbor pulley, and a motor pulley, the ones that are on it now are cast aluminum and the arbor pulley no longer fits tightly, and the motor pulley also needs to be replaced also because the one on it now is a 3" dia., it's supose to be 2 1/4". Maybe a set of cast machined pulleys is in order if I can find a couple locally.
Charlie Lenz
I found a set of steel machined pulleys locally at a more then reasonable cost. Next on the list is to align the blade with the miter slow, the blade is out by a 1/16". Then rewire the saw. Someone wired it with some rediculously heavy gauge wire, the sheathing is atleast 1/2" thick. Then clean up the rest of the saw, and it goes up for sale. I may have got the saw at some would think was a bargain, but when I'm done I'll have a considerable amount of time into it. I look at it this way though, I enjoy working on these old saws, and I feel like I have prolonged it's life.
Re: ( Rockwell Model 10 Table Saw ) Completed
Charlie Lenz
After another full day of working on the saw, aligning the blade, and rewireing it, I'm done. I don't have alot of money into geting it back into shape, but I've sure got alot of time into it.
Charlie Lenz
New electrical box, electrical cord, and plug end. I also added two wire loops to prevent the electrical cord from ever contacting the blade. The old electrical cord had been nicked by the blade twice, one of those times it exposed the black hot wire.
Dale Lenz
Job well done
Dale Lenz
Like your wiring harness idea, ;")
Nice work but I'm amazed at how close
Gary Smyth
this machine is to my JTS 10. Jet apparently made two model JTS 10's. Mine is the earlier version. Anyone aware if this Rockwell 10 and the early Jet are one in the same?
Can't say for sure...
... but if they were made in Taiwan, odds are very good that many of the parts are interchangeable.
Re: Nice work but I'm amazed at how close
Charlie Lenz
Gary, my best guess is that this saw was probably made in the early to mid 70's, I have a Delta version of it that I bought in 1995 and about the only thing thats different is the cast iron part that is mounted to the trunion bars that the motor mount is hinged to. I've never looked real close at a JET, and it's been awhile since I've seen a blue one. Does your JET have the same flared leg stand ?
Re: Can't say for sure...
Charlie Lenz
Ellis, the Rockwell was made in the USA, and Delta continued to make them until atleast 1995 or later. The blue JET's I'm guessing were offered in the 80's ?
Re: Job well done
Charlie Lenz
Thanks Dale, if I was going to keep the saw I would take the electrical box, switch, and the electrical cords out of the saw cabinet, the electrical boxes tend to want to fill up with dust over time. It's a good excuse to buy a large paddle switch and mount it and the electrical box under and behind the fence rail where it's also easier to reach and find.
Steve Schoene
Remember that the earlier "made in Asia" saws are direct copies of the older US designs. Some even used cast parts as the actual pattern for the castings on the knock offs. Others, of higher quality typically, used the design but made patterns so that the castings would be closer replicas of the originals.
Re: Job well done
Brad Chenoweth
Charlie,
Where did you get the box for that switch? I bought a paddle switch from Grizzly, but it's larger than a standard box, and their customer service was of no help in finding the proper size box.
Brad Chenoweth
Pics
Gary Smyth
For what it's worth. The earlier JTS 10 I own. The wheels and extensions are different. I don't know what a blue Jet is.
Purchased in 1972. It has the flared metal leg. Has run forever but has burned out 3 switches during that time. Fine dust gets in and slowly clogs the switch. Other than that, only the 25 5/8" fence capacity has been any problem. Oh, and the accuracy of the scale pointers had much to be desired. I removed them long ago.
Re: Job well done (Brad)
Charlie Lenz
Brad, I bought the box from Lowes. I think it was displayed as a handybox.
Re: Pics
Charlie Lenz
Gary, your JET also has the flared leged stand, which I'm partial to. As far as the switch goes, I highly recommend geting it out of the cabinet and rerlocating it to under the fence. If you need any assistance in doing that let me know.
Robby Wright in San Marcos, CA
Nicely done, Charlie. I have the same saw. I bought it from a buddy that worked at Rockwell on the space shuttle project. I bought it without the motor and added a 2 HP Dayton high service factor TEFC motor. It works like a charm. I added a Biesemeyer fence and right table, and a router table as the left table. The arbor pulley wore out its bore over time, so I replaced all of the pulleys with machined cast iron pulleys and a link belt. They have been working well every since. Line it up right and it is a great little saw.
Robby Wright
