Chest of Drawers mile stone
Bill Tindall
Caught a warm day so I can spray outside. I am spraying old fashioned varnish so I need a few hours of warm to get it dry enough to move inside for cure.
First I spray all the drawer fronts and set them in the garage end up. End up the finish will level and not run if I have made an error in spraying. But end up they are prone to catch settling dust.
Next I spray the frame .
By the time the frame is done enough solvent has evaporated from the drawers that runs are no longer likely, if they ever were to begin with. So, I then insert the drawers into the back of the cabinet so as to not risk touching the wet cabinet face. Now the surfaces are vertical and less prone to catch dust while further drying. Here it will all stay until the finish is hard enough to cure. It is too cold to fully cure in a reasonable time outside, so tonight I will move everything into the heated living area and enjoy the fresh smell of curing varnish.....which means a project is nearly done.
Once this coat is cured I will lightly sand it and apply the final coat.
Re: Chest of Drawers mile stone
Looking good....
You may have to wait until spring for the next coat.
By the way, I think the chest might be upside down and backwards. Give that some thought before you do the final assembly.
Love the smell of drying finish, Something is coming out of the shop.
Re: Looking good....
Charlie Lenz
I'll second on the looking good reply by Barry. But I've got to ask if your going to put a back on it, since you didn't mention puting a back on it. I would think that would be a must to keep the chest from racking.
Jesse Cloud
Looks great, especially the way the figure in the "bottom" drawers popped out.
Congrats on getting to 'light at the end of the tunnel'!
That's a beauty of a chest
Nathan
Hi Bill -
I'm really impressed with your work. Very refined, elegant, and useful.
Nathan
Backs and racking-not a chance!
Bill Tindall
Racking- this thing is held together with 40 dovetails. It would not be more rigid if it was welded and cross braced.
Back- In the beginning I added plywood backs to these kinds of things. Then as what I made got more refined my backs got more refined and I applied ship-lapped 1/2" boards to the backs. My current fashion is to cover the back with a frame and panel panel. It is a long story of a log mis-sawed, but when making drawers I wind up with some 1/4" lumber that I use for the panels. I hate wasting lumber.
Re: Backs and racking-not a chance!
Charlie Lenz
LOL Bill, after posting the first time I looked at the picture a little closer and noticed that you had rabbeted out the sides for a back to fit into. I will also add, nice finish, the side looks as smooth as glass.
smooth as a porcupine
Bill Tindall
What you see is coat #1. All sorts of stuff raises up as this coat dries, and it feels like 80 grit sand paper. Additionally, there are bright and dull places as the first coat penetrated more or less. It will be sanded with something in the range of 320 to 400 grit stearated paper at which time it will be glass smooth. Then I will spray a second thinned coat. I don't want to build a thick varnish finish on the piece. Still undecided if I will rub it out or leave it bright. I have a test piece to help me with that decision.
Looking good Bill
Bob Hackett
I`d also like to say thanks for sharing your process in such depth. I find your project posts to be even more interesting than your posts about tools,steel and diamonds. All your posts are very well thought out and helpful for me personally and you`re one of the folks I always look forward to reading and following.
