Veritas - Innovation in Tools
spring-loaded ball casters
Yonak
I'm going to make my wife a rolling step stool for Christmas so she can reach the upper cabinets in the kitchen. I'm having a heckuva time finding spring-loaded ball casters, which will roll when there's no weight on it and the ball casters will retract when she stands on it, on the internet. Does anyone know of a source I could check out ?
Re: spring-loaded ball casters
Joseph Mulherin
Look at this website: www.omnitrack.co.uk
Rick L
Re: A simple option
Rick L
Never cared much for most ball casters as they pick up too much fuzz and crud from the floor and get jammed up. Mount your choice of regular casters on a bar and springload the bar. Or you can put springs on a stem type caster. There's simple and cheap options using parts from your local hardware store.
Re: A simple option
Yonak
Thanks for thinking about this, Rick. I'm leaning toward your idea of making the spring mechanism. I have checked into compression springs that would go up into the legs.
I have also found a caster from McMaster-Carr that is a spring-loaded swivel-type with a boot that goes down over the caster and provides the support when the spring is depressed, but the diameter of the boot is 4 1/2" and it seems like that would make the bottom of the stool look very bulky. It's going to be a pretty small step stool to start with.
Now there's another facet to this riddle. I was thinking my wife wanted this only for the kitchen, which has a marble floor, but now I learn she also plans to use it in the library which has a carpeted floor, and your warning about fuzz getting into the ball caster becomes even more pertinent.
I'm beginning to think she can carry it from location to location.
