Replacing old unisaw motor...
John in NM
My unisaw is from the 1950's or so, and the 1 HP repulsion induction motor is failing, coming up to full rpm takes a long time, getting longer. I'm working under the assumption that there is little point to having it rewound, as the expense would likely be far greater than replacing it with a 3 HP capacitor start motor.
I'm wondering if anyone here has done such a replacement? Does a new Leeson or similar motor bolt right on? I can do a lot of the fabricating if not, but it's not my first choice for how to spend my limited free time, and in the broader scheme I may look for another saw instead.
Re: Replacing old unisaw motor...
Steve Schoene
The new replacement motors will fit without internal modifications. There is one potential hang up, since the cabinet opening for the motor may not be quite large enough to clear the motor when fully tilted. It is a fixable problem, since you can cut additional clearance opening into the side. (The old cabinets are really sturdy with strength to spare.) That will mean that if you have the old egg shaped motor cover, it won't fit. Of course I think those are scarce and selling it might make a good dent in the price of the replacement motor.
As I recall...
...from my first Unisaw, which was older than yours, it's not going to be a simple plug-n-play. The Delta motors had sheet-metal brackets welded to the motor casing, which no replacement motors do, unless you buy them from Delta. The alternative is to get a generic motor and have an expert welder fabricate the necessary brackets and weld them accurately to the motor housing. I can't recommend this because I haven't done it, but I believe others have. I ended up selling the saw and buying a new one with a 3HP motor.
Hopefully this little kernel of information proves useful....
Re: Replacing old unisaw motor... *LINK*
You would, of course, burn in Old Woodworking Machinery hell for cutting into a 1950s Unisaw cabinet...
Before buying a new motor, you might inquire about the cost of rewinding. The old repulsion-induction motors are said to have more effective oomph (technical term) than newer motors, so it's not a direct 1 to 3 correlation between older and newer motors.
The folks at the link below might be able to help. Just don't mention that you're considering putting in a new motor, or they may send a delegation to your house to take the saw :D
http://owwm.org
That is more or less what I feared...
John in NM
But I could cut my old bracket off and weld it onto the new motor. Probably have to pull the guts out though, or at least have a look inside to see if there's a decent air gap between the case and windings.
I will check with a local outfit about rewinding (it's actually the brushes and commutator, windings likely ok), though I'm not optimistic. We had some motor generators reworked about 10 years ago at the first telescope I worked for, and of course I was discussing fixing obsolete motors with the repair shop. The guy told me a modern motor was usually about half the cost of repairing an old one. Maybe that's changed a bit, as the economy changes, worth a look anyway.
I bought one of those at auction for $50
Keith Newton
Got it home, and found a free delta 3 hp motor with a bad bearing, which I easily fixed,. I don't remember having to do anything to the cabinet. I did replace the starter though, but I usually can fix that with salvage parts that I manage to scrounge for nearly nothing. Sold it to my cousin for $500, with new unifence. I didn't need 4 TS's.
By the way, I know of a nice like new unisaw with 3hp unisaw with a ~ 50" unifence, which can be had for $1250.00 if any of you are interested, contact me.
Go Hogs!!!!!
Near as I can tell...
John in NM
A capacitor start 2HP motor is more powerful than the one that's in it, and roughly the same size, so I wouldn't risk the wrath of old machine connoisseurs.
To tell you the truth, I don't much like the R-I motor. They have high starting torque, but I don't find it more powerful than a modern motor. In order to make use of that starting torque, you have to bog the thing down to the point where the centrifugal switch will re-engage the repulsion circuit. Having done that once or twice, I can tell you there was a significant pucker factor involved, and I'd just as soon go with a bit more power :D
If any of them guys wants to bring a modern saw with a bum motor over here, I'll gladly trade to preserve the historical integrity of my oldie :D
I did find a place in alb. that claims to rebuild, hopefully they do more than replace caps and bearings :D
Man, I hate hear that kinda thing
John in NM
Seems like I always miss those good deals, but on the other hand I bailed out of the real estate bubble at just the right time, so I used up a lifetime of luck in one year :D
I may be in luck
John in NM
Found a diagram of leeson replacement motors, seems to be the same bracket I have as near as I can see without pulling the motor. My saw may be newer than I thought, it's been repainted a couple times so the plate with the serial # is long gone (I'm mostly going by the art deco looking motifs on the saw :D ). Got to go back down and measure the motor length again, I may get away with the 3 hp, but even a 2hp will be an improvement over what's in the saw.
Thanks to all for the input :D
