ADVERTISE HERE - FREE TRIAL
OT Computer to TV-again
Thomas Norton
Thanks to those who have responded to my questions about setting up my computer to stream to my TV. It seems that just when I begin to get a handle on this something else comes up to confuse me. Funny I don't have this problem when I do woodworking!!
Anyway here is where I am. I understand that a Roku will work @ the TV aand that if I can sanke an ethernet cable back to my computer location that will work. But last night I was reading that I would need a "wired network"? Once again I am lost. Give me wood!
So what do I need at the computer?
And one more question. I want to watch Hulu, not Hulu Plus which is a subsription service, on this set-up. But am I right that Hulu will only work on the computer?
Thanks ALL your help!
Tom
Re: OT Computer to TV-again
Chuck in Mtl.
a network can consist of hardwired locations like you want to do or a wireless network that has no actual wire, only computers and laptops that connect thru wi-fi.
Stuart Johnson
I'm not sure why you want to go with the hard wire but the way my Roku works is wireless. The Roku is connected to the tv with an HDMI cable and connects to my wireless router just as if it were a wireless printer or other device. When setting it up it will as the normal connection information and then just be another connection. When ROKU is selected on the TV you have a list different channels you can add. You select the one you want and it give you it's menu.
These threads got me to thinking about hooking my laptop to the TV. I used the ROKU HDMI cable and pulled up a NETFLIX movie it worked just fine with the exception of the audio. I have to figure out how to get the sound as well but at least hooking up the computer was easier than I thought.
Bill Howatt
I don't fool with this stuff but the Roku site says most people use wireless. Given the relatively low speed of internet connections, even the fastest ones, it seems any wireless should work with the Roku.
Bill
Dean Q Johnson
I 'cut the cord' on satellite & cable TV awhile ago and would say I have had mixed (but mostly good) results. I use ROKU and can say that you will want a relatively fast internet connection. Most sites say that 2-3 mbs connection for ROKU can work, but I found that speed to produce a lot of interruption and a sub-standard experience. I have a 8mbs DSL line feed from my Telephone/ISP now and generally have not had a lot of problems.
I have a direct ethernet cable connection to my ROKU in the shop which has worked well. In the house we have a ROKU set up in a wireless network which caused some problems initially, but became much improved when I split the "wireless load" by using a dual band router. I run the laptops, wireless printer & (I think) the cordless phones etc on the 2.4 gigahertz band and reserved the 5 gigahertz band for the ROKU and the streaming content. As long as the DSL line can keep the download speed in the 6-9 mbs range we have very little interruption and an excellent picture and sound.
Bill Howatt
Interesting. I have a dual-band router and they certainly hype the use of the 5Ghz band for TV. Apparently there can be interference on the 2.4Ghz band from portable phones, neighbour's routers, etc which can disrupt communications. These disruptions may not be obvious in non-TV applications.
Bill
