cracked fingers
cracked fingers
cracked fingers
Jerry Gibbs
My fingers have begun splitting and cracking from the cold, dryness and woodworking. I am thinking of using close fitting gloves, like mechanic's gloves, to allow me to keep balm on my hands and protect them. I will be using mainly hand tools, but also a power oscillating belt and drum sander. Any suggestions are appreciated.
Re: cracked fingers
Wear the balm and gloves at night
John in NM
I often have do this at work, since I stay at the site for 7 days at a time and the high elevation makes for very dry air in the winter. I actually prefer leather gloves to rubber.
Re: cracked fingers
Re: cracked fingers
Ken Oakley- Sunny St. Cloud, Fla.
Move to Florida where it is rarely cold and dry. Mineral oil works well also. I have seen numerous serious injuries by people wearing gloves around rotating machinery
Re: cracked fingers
Re: cracked fingers *LINK*
Stuart Johnson
Try O'Keeffe's Working Hands Cream. My wife has a terrible time with her fingers cracking and tired it last year with great success. She uses it daily You can get it at any number of places on line but we found it at Lowes in the paint department.
Re: cracked fingers
Re: cracked fingers
When my skins starts to crack I use Bag Balm. Seems to help. Also agree with Jason, keep hydrated, More water that you might think is better. Shoot for at least 64 oz a day.
I am skeptical about leather gloves. Sort of two minds. I wear one on my left hand when turning on the lathe, but I have cut the fingers out of it. I touched a turning that had a very sharp edge on it and Te glove has a nasty gash. I am not sure I would have been so casual about touch a turning without the glove, but I do know it would have been a terrible cut on my hand without it. Don't think I would object to a glove and sanding drum combination.
Here's the sort of weird piece of advice. I find my skin cracking alone the sides of my fingertips and collecting dirt and getting sore. I use a piece of sharp 100 grit sand paper and sand away the cracks. I sand down to fresh pink skin, sanding away the callus. I think the thick skin cracks and the cracks spread into the healthy skin below. This may not be your problem, but it works for me and is not painful and helps a lot. Abrade them Dow to the tender skin and coat with Balm.
What works for some people does not work at all for me. Apparently it different strokes for different folks. Try clove oil. It works for me but I hate the smell.
Re: cracked fingers
cracked fingers - kind of long
Al Goldstein
I had skin cracks on my fingers for years until I found some solutions. I hope that what worked for me will help others.
I agree with keeping hydrated. Being well hydrated aids the body in functioning in many ways (bowel function).
I use Aveno Daily Moisterizing Lotion in the winter to prevent finger cracks. Many skin creams will help. Jergens Lotion will work if you wet your hands first. Jergens will not be fully absorbed by dry skin. A top dermatologist told me to wet my hands under a faucet and then shake them only once. Then apply the Jergens and keep trying to rub it in. After 2 or 3 minutes it will suddenly be absorbed. Strange but true.
I agree with the sandpaper solution Barry uses for deep skin cracks. It also will work for paper cuts that heal slowly. Here is my theory. When skin has a deep straight cut the skin on the sides of the cut dries out and becomes rigid. Normally the skin is elastic. So when it is distorted by normal motions the distortion is shared by all the dispaced skin. But the dry rigid skin adjacent to the deep crack moves as a whole so the healing skin in the crack has to absorb all of the distortion. This interupts the healing process of this skin and it has to start over to creat a scab. Without the dry skin present the healing skin in the crack moves much less and its healing is not interupted. So using your hands greatly slows the healing process unless the dry skin is removed.
I use a nail clipper to cut off the dry skin adjacent to paper cuts. When I finish the skin on the sides of the cut appears red and is again elastic. Very little pain and the cut heals quickly because it is not overly stressed.
Hope this helps. Good luck.
Re: cracked fingers
Re: cracked fingers - kind of long
Dale Stansbery
I treat the cracks with a thin film combination anti fungal/antibacterial cream a couple times a day along with a good hand lotion. It's the secondary infection that makes the cracks hurt.
Re: cracked fingers
Ah, a new cure for Itchy Backs
George Colonel's Workshop-Havertown PA
Good Afternoon Barry,
Sanding my back sounds completely wonderful and, thanks to Klingspor, we have the right stuff to use. 80 grit on a ROS is perfect for mornings, and some 220 on my PC 330 orbital Speed Block is soothing and relaxing after the nightly shower. I had my back cracked once in a Japanese bathhouse, but that is another story.
George
Re: cracked fingers
Re: cracked fingers - Super Glue!
Henry (Raleigh NC)
Wow - eight replies above, and no one has mentioned my remedy (not unique to me though).
Cyano-acrylate adhesive (aka Crazy Glue or Super Glue) seals the crack quite well. The biggest hazard is the wet glue and the ability to glue fingers together (it is after all an adhesive, why they make the stuff). I simply put 2-3 drops on the crack and that covering or coating lasts until it heals.
Henry W
Re: cracked fingers
Re: cracked fingers
gary camp Bend, Oregon
I'll second O'Keefe's Working Hands Cream. Best stuff I've ever used, my feet crack sometimes in the summer, just a couple of applications and back to normal.
Re: cracked fingers
Don't use the accelerant. It gets very hot. You WILL say Ouch or at least your eyes will bug out. The medical version of the glue does not get this hot.
Re: cracked fingers
Jerry Gibbs
I'm told that water is a good excellerant. Don't know about the heat. Maybe a test on something besides your body.
Re: cracked fingers
Triamcinolone Acetonide Ointment, USP, 0.1%
John McGaw
Great stuff and although it is prescription-only it is really cheap. You might ask your doctor about it. It has worked wonders on any number of dry and scaly, cracking, and irritated skin problems for me. Basically it is petroleum jelly spiked with a tiny amount of a synthetic corticosteroid.
Re: cracked fingers
Tried it...
John in NM
Works great for cuts, especially nice clean vertical cuts, flaps of skin less so. I find the moisture and oils from your skin are plenty accelerant enough, no need for anything else. If it won't bond, the cut is still too wet (blood and lymph).
I've not found it effective on cracked callouses however. Covers them up for a while, but doesn't really solve the root problem - dry hard skin that shrinks and cracks.
