OT-Ethernet cable
OT-Ethernet cable
OT-Ethernet cable
Thomas Norton
I am thinking of using a long ethernet cable to run from my computer to my TV and have a question. Is there a wall plate that I can make a "neat" install similar to running coaxial cable?
Thanks,
tom
Re: OT-Ethernet cable
Re: OT-Ethernet cable  *LINK*
wilbur
Plenty of options. Here's a Google shopping search for "Cat 6 plate".
CAT 6 wall plates
Try Either of the Big-Boxes
Steven P. Bellner
Go to the the electrical dept. and there will be an area selling home audio-video and telephone wiring supplies. You will find an endless array of products. I like the On-Q brand of mix-and match wallplates - I can bring coax, cat5/6, telephone, and speaker connections to a single plate using snap-in connectors.
This is all low-voltage, so you can use a low-voltage old-work box if you don't already have a box in-place. It's a lot easier to manipulate the wires with this box vs. a standard deep box. I'd avoid not using a box, as you will eventually damage your wallboard. Just make sure you don't let go of a wire as the low-voltage boxes don't have built-in wire clips.
For the ethernet cable, you can get two types - one you will need to wire (it uses punchdowns) and the other is essentially a coupler where you simply plug a previously terminated cable into the back. Snap the connector into the wallplate, screw it onto the box, and you're done.
Or Radio Shack
Just so you know…
Rod Peterson—Ormond Beach, FL
And I speak of this from bitter experience, the plate/connector sets at Lowes are not compatible with the same type of fixtures at Home Depot. Subtle differences, but they keep one connector from fitting into the other's plate, although they serve the identical purpose.
Rod
