$14 gallon for mineral spirits
Mike Farinella
at the borg today. It's been a while since I bought it last but isn't that a lot of money?
Rant off
Mike Farinella
Rant off
Re: $14 gallon for mineral spirits
JMOHNIKE
In Calif. they have again chaned all the rules, thanks to the EPA, and the new stuff, from thinners to staines, has been changed, and costs more. Some people I know have started useing gasoline to clean up brushes, etc. because of the cost, which defeates the EPA.
Gasoline works and is cheaper
RobCarr
I have always (30+ years) used gasoline to thin paints and clean brushes. It's one less thing I need to keep, since I'm already using gasoline for the garden tractor, etc.
Flash point
Alex Grigoriev
Here is a little bit of difference.
Flash point for MS is >100F.
Flash point for gasoline is -45F. Gasoline vapors are heavier than air.
What does that mean? A quart of gasoline, evaporated in the garage, and with vapors spread on the floor will make an explosive mix even in the winter.
thinner?
Bill Tindall
I have always used gas to clean oil based finishes. Its volatility is an advantage as it goes away quickly when disposed on the driveway. Cleaning a brush with gas can be no more risky than filling the lawn mower. Neither should be done in the garage or near the grill. Anyone with flawed judgement should of course use mineral spirits or better yet water based products.
But thinning? While gas contains highly volatile components like butane so your car will start in MN, it also contains quite nonvolatile components. I tried thinning once where I didn't care about the result and found the paint smelled like gas for days and was slow to harden. Additionally, the highly volatile components could cause bubbles while drying. It isn't a practice I would recommend.
Re: thinner?
TomD
While it is a little OT, I have three approaches to this stuff:
-Water based paints Behr Super White interrior/exteriror straight or as a base pretty much gets me to where I want to be.
- Dollar story brushes that are as good as brushes sold at HD a few years ago. Only good for water based products, though.
- Brush conditioner, this is like hand creme for brushes, and makes the mess a whole lot easier to clean up. The stuff I have is FLood Brush Stuff. A tiny dab i'll do ya. I got mine at HD, but it seems to be an Au company:
http://www.homeimprovementpages.com.au/connect/the_flood_company/brochure/brush_stuff
At least it's less than $300 *LINK*
This will explain the subject line
