OT: Youtube Problem
Stuart Johnson
All of a sudden I am unable to view Youtube items. I can access okay but the video screen portion is blank, just a black screen. Any idea what has happened? I would like to avoid a restore if possible.
OT: Youtube Problem
Stuart Johnson
Re: OT: Youtube Problem
del schisler
you need adobe flash player 10.3 . Check and see which one you have . that is what the U Tube player goes thro.
Dave's Not Here
Before I updated to Windows 7 I had that same problem when using Internet Exployer with Windows XP. However, for some reason beyond my knowledge of comuters, YouTube worked fine with Firefox and Windows XP???
John McGaw
What browser do you use? Have you made any changes to it lately like settings or add-ons? For example, I use Firefox and have the NoScript add-on and unless I explicitly allow YouTube access from within a web page it will show up as a black box as you describe.
Stuart Johnson
I'm running Windows 7, FireFox 8.0, my shock wave plug-in is 11.1.102.55 the most current version. I am able to view Youtube with I.E. but not with FireFox. It's acting like it is a FF issue but I can't see where. If I disable Shock Wave the video says I need flash (don't remember the full text). If I enable it no longer says I need it but the video doesn't load or even show that it is trying.
Stuart I had that problem for about a week 6 months or so ago. I never did find out what happened. It just came back without any care on my part.
TomD
If you think it might be temp, run Crap Cleaner.
Re: OT: Youtube Problem - udate *LINK*
Stuart Johnson
Some video will play but most won't. I think the ones that do might have a different type of coding. Anyway, after going to FireFox help I find this is a flash issue not FF and has cropped up in the past. A couple fixes are posted but usually a new flash update will fix the problem. This is probably why John had the issue and after awhile it just went away. The link below explains what is going on.
Firefox, Youtube and Flash
Flash Player new up date is 11.1
