What tool to use...
What tool to use...
What tool to use...
Falkner
Hello -
I've been mulling over this for a while now, attempting to come up with a solution, and have decided to turn the problem over to the experts...
I'm building a wooden boot, 13 inches from sole to top, 8 inches from toe to heel, with a 6 1/2 inch opening at the top, (where you'd put your foot in if it was a real boot).
Since I want the inside hollowed out all the way down to the "toe" of the boot, I've decided to cut the two "halves", (featuring a vertical cut down the center) and hollow out each side.
Here's the issue: I'm looking for a relatively "quick" way to hollow out the majority of the boot, (ie everything except the toe). I've done the lionshare of the work with a reciprocating carver, but I want to do many of these in a short amount of time. I thought about a spindle sander, but I can't seem to locate any with a ten inch (or more) spindle, and I'm not sure how the spindle would hold up doing three to four of these "boots" per day.
Any ideas would be greatly appreciated!
Thanks.
Re: What tool to use...
Moses Yoder
Moses Yoder
If you put them on the lathe before cutting them in half, you could hollow out the top of the boot pretty quick, probably as quick as anything.
Falkner
Concerning the lathe, I'm worried about them being an "irregular shape" and getting a "centered" hole down the middle. (Obviously I don't have a lathe yet...) Is this something I need to be concerned about?
Moses Yoder
Moses Yoder
I don't do a lot of turning, you might ask this question on the turning board. I pictured the boot being bandsawn to rough shape and mounted on the lathe with the leg in the center and roughing out a hole then cutting in half and finishing the hollowing.
Falkner
Thanks much. :)
JMOHNIKE
Prior to cutting in 1/2 you could remove a lot of material with a drill press and spade/paddel bit. Then cut in half. You could then used a drum sander on a flex shaft. The flex shaft would also allow you to use various rotary rasps and files to speed up the process.
Good Luck
Joe
Falkner
I thought about a drill press, but I guess I was worried about finding one with a thirteen + inch amount of clearance...
JMOHNIKE
You can drill down the max depth, then (with the bit still partially in the hole) raise the table being careful not to drill too deep.
I tend to think in terms of what tools I have. I have several routers and a band saw. I might rough out the exterior of the boot with the bandsaw and then split it in two. Then I would set up a pattern with the outline of the boot. A frame on the outside to index the pattern onto the roughed-out boot. Then I would use the routers with core box bits to cut out the inside. By starting shallow at the perimeter and going deeper toward the center you could sculpt the inside and leave very little to clean up with a rotary rasp and perhaps a flap sander. You might need a set of patterns. A bigger one to give you the perimeter and smaller ones to do the deeper parts. And a set of lefts and rights to do the other half. (I have a core box bit that is about 1 1/2" in diameter.)
Then you could shape the outside.
If the "boot" is split lengthwise
Gary Smyth
and the lumber is easily carved like basswood for decoys, do the inital hollowing by hand with a scorp. If you can get a Foredom tool you could get real close to what to want quickly with the proper head and get closer to the end result with better control.
In my jungle . . .
steve mackay
when I hollow out a STRYKER Infantry Fighting Vehical (13"x5"x4.5") I go to town with my Dremel and a 60 grit sanding drum. I've seen those keen burrs but I'd get carried away. Takes awhile but its safe. I found that its REALLY easy to loose track of things and go "right on through to the other side" !
Re: In my jungle . . .
greg
I may be envisioning this wrong, but it seems that what you are doing is very similar to making a Dutch wooden shoe. Perhaps you could resrch how those shoes a made and take some pointers from that.
Keith Newton
I'm guessing you are using green wood, and have plenty to clamp onto to begin with?
I would start the roughing out with a chain-saw. Then I would follow that with a long-neck grinder fitted with a rotary chisel, with a 1/4 to 3/8" flute. I think creative technologies may be the brand search for. They have three blades on a solid carbide tip, ground in such a way that they cut fast and easy without the snag potential of a core-box router bit like Barry suggested. These are expensive cutters, but it will pay for itself in time savings and control.
If you feel that you need to shape the outside first to know how much to take out of the inside, I would suggest leaving an extremely high heel, for clamping in the vice, that you finish off last.
Don Orr
Take a look at the Arbortech mini grinder. It works very well with a Kutzall type wheel. Fast cutting and fairly controlable.
Here's what I'd do. If your cutting it in half you can easily drill away most of the waste similar to drilling a mortise. just use a Forestner style bit and whittle away. You can get rid of 90 percent of the waste this way.
then use a Dremel or flexshaft with one of the Ball shaped carbide burr style bits to get rid of the rest. Once that's done you can easily hand sand with very course paper to clean up whatever else needs cleaning.
I do a lot of work like this and it works very fast. I have fancier power tools and lots of hand carving tools but the method I mentioned above is how a lot of my work is done. It's just faster and easier most of the time.
Keith Newton
Don, I like your suggestion of the arbortec. I have both large and small, but not the cutzall blade. Both would be good to follow my suggestion above, of starting with a chainsaw.
Re: What tool to use... *LINK*
Bill Hammond
I have seen this tool used to carve out large areas on a totem pole. It was fast and when the fine tooth blade was used the surface was surprisingly smooth.
He used a variable speed 4" grinder and said it took a few tries to get the hang of using it.
King Arthur Tools Lancelot Woodcarving Disc
