Re: Checkering . . . ?
TomD
Yeah they are designed for hardwood. They will work on softwood to the extent that anything does. It would be like filing with a triangular file. I don't know who has them in Canada, I could ask for you on Gunutz, if you aren't a member. You may want two relatively cheap tools, the cutter, which is sold on a line per inch basis, and a jointer, which is a longer single that allows one to straighten runs if they start going off line. I have the two tools, and am just down the road, but I haven't seen then in a decade. If you actually wanted a grip type thing, you could use a stippling tools. Another option is one of those air tools that breaks off the slag.
I think the answer on gun tools is that everyone up here uses Brownells. They have a huge catalog. While getting parts up to Canada is becoming more nightmarish all the time, the tools are not a problem. Brownells still deals with Canadians, many outfits that sell gun stuff will not deal with us at all, even to send us stuff in no way gun related.
http://www.brownells.com/.aspx/pid=6780/Product/GUNLINE-JOINTER
I didn't see the tool I bought in there, it uses small interchangeable heads, and was cheap. Must be in there since the heads are available.
