Small wine cabinet completed (pics)
GolfSteve in Calgary
This is a small wine cabinet I built for my Mother-in-law. There was supposed to be a matching wall cabinet, but this project was repeatedly delayed due to the arrival of my two daughters over the past five years, so the wall cabinet has been postponed. Below is a shot of the original design that I sketched up while on an airplane. I followed up with detailed CAD drawings to work out the proportions and dimensions. Dimensions are 28” tall, 26-1/4” wide, by 17-1/4” deep.
It’s made of solid cherry, with cherry, cherry crotch, and maple burl veneers hammered onto Baltic birch panels. The knobs are African blackwood, and the Krenov style door catches are cocobolo.
The finish is a mish-mash due to the extended construction period, but is mostly a coat of shellac, followed by dyed shellac for toning, a seal coat of shellac then two coats of gloss water based lacquer and one coat of satin water based lacquer (Target EM6000). I only recently started using the satin top coat and I really like the sheen. I started out with a French polish finish but eventually scrapped that as my spraying skills improved over the years that this project took to complete. I also found the finishes on older pieces that I had French Polished were being damaged by water stains, scratches, lamp impressions, etc, whereas the Target finishes have been much more durable.
This is the first time I started with 8/4 stock for all the door pieces and resawed book-matched stiles and rails for all the doors. Brusso knife hinges were used (a first for me), and Krenov style door stops (a first for me).
Rear View
Can you find the joint in the top?
Veneer softening:
Drawer slips were used. I put a false divider at the rear of the drawer to give people a warning before the drawer is completely pulled out, and also forms a small hidden compartment.
Everything that could go wrong with this project did, and there is one flaw that I didn’t fix too well when I sanded through a run in a dye-coat where I just said “@#*# it, I gotta finish this thing” and used a touchup pen to hide the flaw as best I could.
The inspiration for the design of my cabinet was from the following photograph that I copied from the Internet years ago and I don’t recall who made it:
And a final shot showing the disaster that was my shop in 2009 when we reorganized the house and cleaned the carpets before my second daughter was born. If you look carefully you can find bits and pieces of this cabinet strewn about the place.
