Local body shop for spraying furniture?
Bill Tindall
I have a chest of drawers to finish soon and it may be getting too cold to do it conveniently. I was thinking about approaching a local body shop to see if I could use their spray area. It is heated, and it has good lighting and ventilation.
Has anyone tried this route? Any problems I have not anticipated.
Re: Local body shop for spraying furniture?
Nat Robison
First off, I have no experience in this but I saw a website for a collision shop near me and in addition to all the before and after pics of car repairs, they also featured a wooden kayak that they had sprayed at their location. I think if a shop has a talented painter, they should be able to handle your project without much problem. Certainly, vehicles come with as many if not more contours, angles, etc. as furniture does. The only hangup I can foresee is a shop not being familiar with the products used to finish furniture.
Chuck Kettler
A 12-pack of Bud and a half gallon of red eye will oft provide the needed lubrication to your desired end.
the "price"
Bill Tindall
I had better be sure they didn't help any if that was the price!!
I would bargain to get access to the shop like Friday evening, spray and then remove the cured cabinet Monday AM. I am spraying conventional (actually old fashioned) varnish so it will take a couple of day to cure hard enough to transport. Anything else and I would just spray in the driveway and move inside to cure after the finish set. The smell of aromatics, ketones and esters rejuvenates me.
If you go that route
Dale Lenz
might see if you can use one of their Sata guns, would love a report if you use one.
Jim Hager
I'd think that would only be available if you have a good relationship with the guy who runs the shop. I know in my shop someone who asks to do something like that without being a real good personal friend would be shot on the spot. I know you have good intentions but your project will get in the way of their workflow and cause a loss in production. Even when I allow a good friend to do something like that in my shop and it happens once in a while, it always bites me in the butt in one way or another. I've learned to say NO.
If you want it sprayed, ask them to do it for you.
Nat Robison
When I read the original message, I thought you were inquiring about having them spray it for you and I posted as such higher up.
I agree with Jim. Unless you're a friend of the shop owner, you'll probably be told no in a polite or not-so-polite manner. From your post above, you're basically asking if you can spray after hours on a Friday, leave your piece in the booth so it can't be used over the weekend should the owner want to and then arrange to get it out of there Monday morning. Good luck if you're able to find that arrangement.
I'm thinking if you supply the finishing material, a shop would probably do the job for $100 or so. However, if the curing schedule doesn't mesh with their schedule, you're probably out of luck.
Prob-Lems
1. Their vent system is designed to handle automotive finishes; very different from spraying varnish.
2. Their insurance will cover neither you nor your piece; that alone may close the door.
3. Assuming you take your own gun/equipment in for the job, your chances ( i suspect) will be slim. If you propose to run varnish through their equipment? . . . NFW
I have tried (paint) here
Gary Smyth
in Western PA. No go. Of course I don't know them personally or them me. When I asked I got wide eyes and a firm "no". I tried two exclusively body shops, and one garage all of which have done some work on my stuff before. Just not their business. I didn't even bridge the subject of me doing the spraying.
Bill I gather the conventional wisdom here is that this ain't going to work for you.
What I have done in the past is take my stuff to a friend of mine who owns a cabinet shop and he finises it for me. He uses catalyzed Lacquer Which suits me fine. He is better at finishing than I am. Of Course, we are life long friends. Oddly everything I take to him comes back resembling a kitchen cabinet. :D
Might be better for you to try a cabinet shop.
Jason Roehl in Lafayette, IN
I've done it.
But only once, and it was a special situation.
The setup: I was approached to donate my labor to spray (paint) a dresser as part of an Eagle Scout project. I also donated a little advice on the prep work. I think I may have both primed and painted it, but I don't recall. Anyway, the Eagle Scout candidate had also managed to get a small hot-rod shop to donate the use of their spray booth. They were friendly and accommodating. It probably didn't hurt that I kept the drool off their works-in-progress, though there was drool. I also furnished my own spray equipment (a turbine HVLP w/compressor).
I suspect that your best shot would be smaller shops like that, particularly a place that isn't constantly using their spray booth, and I'm sure it wouldn't hurt to be buddy-buddy with the owner.
Otherwise, it's pretty tricky to spray in a shop attached to an inhabited structure in the winter months.
Jason
Filters
Phil Smith
Depending on how the booth is set up your biggest issue may be with filters. Since you are spraying an old fashion varnish I assume that it is air cured. OSHA and insurance companies are real particular how you handle filters with air cured varnish. Most auto refinish materials do not self combust when not properly stored.
Correct
Howard Acheson
A couple of years ago a friend needed to varnish a kayak. The two auto paint places he went to would not allow oil based finishes to be sprayed in their paint booth. He was told that they would mess up the filters and scrubbing equipment. These days of VOC regulations require expensive equipment for commercial paint operations.
I remember an outfit that rented bays....
John in NM
Though that was ages ago, it may not have been a good business model. You could look around for something like that.
I know you have proper equipment and would likely prefer to use your own, so that would be no worry.
I would bet though, you'd have more luck with a local furniture or cabinet shop, if there are any with a decent booth or ventilated room. The concept won't seem "odd" to them and in this economy you might find one hungry enough to love the notion. For all the hand wringing about insurance and the like, I think you'll find a lot of normal people don't sweat that stuff.
